SAMSUNG PS50B450 funny stripe
  • tempoedv
    • Dec 2013
    Hi Community.
    I have a SAMSUNG PS50B450 with a lot of problems, some have been solved, one haven´t.
    History of the PLASMA TV
    as I got it there where sound but no picture. All I know at that stage was, it has been in a workshop and one of the power boards where gone. By looking at the Mainpower-Board I saw that some work has been done at it and one of the FETs has been desoldered. Resoldered that and still no Picture and also no sound. Decided to buy a used spare. After fitting and powering on Sound but no picture. Decided to swap the Y-Sus Board. After replacing that, sound and picture came on. By checking picture quality I saw a stripe of darker and brighter pixels from the center of the Display to the right end of the display vertically. Affected was only one third of the display started from the center. If you devide that Bar into three parts the middle one was the funniest. The left and right one appeared more like a shadow with a chessmate pattern.
    After 2-3 Minutes of running the TV the picture was gone and the heatsink of the Y-Sus started beeing hot. I checked the other heatsinks, they appeared as normal. Got a new one and also replaced the Y-Buffer. Turned on and picture and sound came on, but still the bars from top to down of the screen. Went further and replaced the X-Sus Board (only the upper Board) and now after adjusting Va, Vs, Ve and VSC Voltages picture stays on and the stripe of funny pixels is nearly gone, used a DMM set to 250V AC used the Connectors from the Mainpower-Board to adjust Va and Vs, other is taken from the testpoints on Y-Sus and X-Sus.
    Only a brighter bar of pixels stays and I can´t get rid of them. The picture as such is visible through the Bar. It seems only the brightness in this area is not adjustable.
    I also went into the service menu with the button-combination and reset everything to their defaults.
    I left it running for, at least, 2 Hours and after playing around with contrast, brightness, sharpness and cellbrightness the bar is nearly adjusted out. I matched the rest of the screen to the brightness of the bar.
    Question is now what can now still defective? I tryed to put some pressure on the ribbon connectors down on the "Z-Board" (it is the board on the bottom of the TV), thought could be a loose fitting cable, but no change. Cleaned also the connectors for the cables comming from the T-Con Board.
    T-Con Board it self damaged? Anybody here with same sort of problem and a solution?
    I will be appreciated for your help.
    Tommes
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: SAMSUNG PS50B450 funny stripe
    set may have played a long time with a bad buffer and now you may have some image retention(burn in)
    play the set full white a while and see if it fades.
    had an lg with a dead x buffer due to a resistor loose on ribbon(common)
    it had been played a year that way.ran at full white a few hours and it faded a lot.
    now its gone completely.not bad for a 2 year old set at the time a friend came up with free.
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • Mgiffune
      by Mgiffune
      06-09-2024, 10:28 AM
    • Ierwin
      by Ierwin
      05-13-2025, 03:31 PM
    • jchang
      Samsung UN70NU6900F no picture and no sound
      by jchang
      Hi all
      I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
      Symptom:
      No picture no sound.
      When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
      No sound at all.
      What I tried:
      1. I tried unplugging the left or right ribbon...
      01-09-2023, 06:28 PM
    • Dodgethis
      Samsung QN75Q6DRA, No Picture, Has BL, and Sound
      by Dodgethis
      Hello all,
      This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
      09-11-2024, 07:39 AM
