Hitachi 55hdt79 plasma no voltage from powersupply
  • snake91876
    • Feb 2013
    • 236
    Got a 55hdt79 from a lady for free. This plasma had been sent to
    A shop but never repaired. Opened it up and ysus buffer has been removed
    So I assume they had ysus problems. She said he didn't know what he was doing.
    I check voltage to power supply which is good but I have no vs or voltage
    Off power supply to Zeus which also powers ysus. I unplugged ysus
    And still no output voltage off power supply. Is their anything on main or logic
    That tell not to put out voltage. I will post pic of power supply.
  • snake91876
    • Feb 2013
    • 236
    Re: Hitachi 55hdt79 plasma no voltage from powersupply
    Anybody?
    • freakaftr8
      • Oct 2012
      • 3743
      work on one of these before I had a buffer board short which loaded down the ysus which shut down the power supply power supply will not come back up until you disconnect all cables and all connectors that go into the power supply.then let the TV set for 5 minutes and then connect everything back up to the power supply Again. of course you will be doing this with the power disconnected from the TV now when you reconnect everything connect the Y back to the TV but leave the buffer ports upper and lower disconnected power up and see you if you have vs and Va
      • snake91876
        • Feb 2013
        • 236
        If I get no voltage with ysus buffers unhooked could the x sus buffers short
        Out and make the power supply give no voltage, in other words if I
        Unhook power wire from xsus which supplys y sua also should I have voltage
        At plug on powersupply board with nothing hooked up.
        • snake91876
          • Feb 2013
          • 236
          So I unplug power supply plugs for 5min and turn it back on with ysus buffers unhooked
          And wallah I get my vs volatages back of around 85v on xsus and ysus but after
          15 to 20 seconds I lose the voltage to 0v all at once. I still have no images during that
          Time should this thing run on just x buffers or upper and show partial screen.
          • freakaftr8
            • Oct 2012
            • 3743
            No you need ysus buffers Connected. Guarantee one buffer is shorted. Try one at a time. Tv.will shutdown due to power saving after like 10 seconds. So the shutdown is cause of that mostly.
              Hitachi plasmas are right nightmares to diagnose.
              • snake91876
                • Feb 2013
                • 236
                So I got the manual and tested voltages on powersupply. I have all the correct standbyvoltages but on plug going to main board at bottom it has a pin that says 5v and
                I only got 3. Then three pins should be 12v and they are only 10v.
                Could this elude to a power supply problem.
                • anotherdude
                  • Feb 2013
                  • 488
                  remove the cable from the main board and test the voltage again
                  • snake91876
                    • Feb 2013
                    • 236
                    Will not power with main unhooked. Pins 13 14 15 say12v on
                    Chop plug and I only get 10v
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      both your voltages are dead on 2 volts down test your meter on a brand new battery also replace your meter battery just in case.
                      • KYBOSH
                        Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                        by KYBOSH
                        Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                        No picture but you hear the TV static (white noise) playing loud and clear.
                        The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                        But it seems they didn't get too far and just left it.
                        When I first took a look I was amazed at how pristine the inside looked.
                        Its as if the TV had been in a time capsule.
                        Caps looked like they were just pulled off the self.
                        Copper coils had no sign of corrosion on...
                        02-01-2023, 11:10 PM
                      • Yanleb
                        Hitachi Plasma TV 42HDT79 firmware upgrade
                        by Yanleb
                        Do you know where I can find a firmware upgrade for the Hitachi 42HDT79 plasma TV? My set currently has firmware V0112.0001.
                        Their service website seems to be on SalesForce now, which requires a login.
                        Thanks.
                        11-05-2021, 11:55 PM
                      • Jaime Morillo
                        Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                        by Jaime Morillo
                        Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                        The TV was stuck on the logo and I couldn't access the update menu.
                        I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                        The image result was good, but the image is inverted.
                        The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                        Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                        08-18-2025, 11:38 AM
                      • PlasMatt
                        LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                        by PlasMatt
                        I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                        09-20-2025, 06:50 PM
                      • canadaboy25
                        Hitachi 55HDX99 Plasma Powers on but no picture
                        by canadaboy25
                        Hey guys, I recently acquired a Hitachi 55HDX99 plasma TV that doesn't work. The TV powers on and eventually goes into standby which is indicated by the blue power led changing to orange. If I plug a VCR into it to keep it awake, I can feed an audio source in and it will play the sound no problem. The volume controls on the TV work as well so it is obviously just a display problem.
                        I found the Hitachi service manual online which is also hosted on tom66's manual archive. Compared to the Panasonic service manual I had for the last plasma I worked on, this one is underwhelming to say...
                        03-22-2019, 12:06 AM
