The problem with my tv is that, there is no picture, I got the backlight LED-s changed, but still no picture, the only thing that i have is sound + the tv seems to work cause when i press buttons on the remote the screen changes light a little. Could anyone give me an idea about what to look at? or what the problem could be?
Philips "55". 55put6400/12
by Patrick501Hello,
I'd like to repair a Philips 55PUS6704.
It turns on and you can see the backlight, hear the sound but no picture.
When I disconnect one of the T-con cables, half of the screen turns white.
right cable disconnected= right side white
left cable disconnected= left side white
When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
Also you can notice one single... -
by RauniHello, this is my first post on this forum, and my first attempted to repair a TV.
My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
Read also that we should test what happens if we... -
by SchwoinHey everyone,
the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
you can see them on the top half of the photo.
At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
by madyoyoHI.
I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming.... -
My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
Is there someone having any symptom like this? How to fix it?
Thanks in advance!08-06-2024, 09:55 PM - Loading...
