LG 50PK550 - Screen flash, then gray
  • L33TN00B
    • Jan 2014
    • 5
    • South Africa
    Hi there,
    I have a LG 50PK550 Plasma. Last week, the TV suddenly powered off while playing music from my RASPBMC setup. I disconnected the TV from power and reconnected, tried to power up....
    The screen flashed for a second then went gray and stayed like that. The remote and front panel controls are unresponsive.
    I removed the back cover and tested the SMPS's fuses, diodes and power resistors, which all work. Then I tried the AUTO_GEN test pattern, with the LVDS cable disonnected from the mainboard.
    The test pattern worked!
    Does this mean that the mainboard is defintely the culprit?
    I've read some posts on these forums saying that a bad firmware flash could be the problem aswell. I will try using as null modem cable this evening to see if it is indeed the case.
    Another thing I'd like to try is resolder the BGA chip and the surrounding components on the mainboard.
    Please let me know if my troubleshooting has been correct so far...
    Re: LG 50PK550 - Screen flash, then gray
    Yes, you have a bad main board. This is a common fault on LG's premium plasmas.
    • L33TN00B
      • Jan 2014
      • 5
      • South Africa
      Ok, thanks, I'm going to try see if I can get into the board using the serial port and using Putty to see if overwriting the firmware would work. How would one overwrite or flash the firmware using the serial port? What are the commands I'd use?
      • anotherdude
        • Feb 2013
        • 488
        • uk
        check the service manual a lot of info about the service port is usually in there
          The RS232 is mostly for control only, to allow you to remotely change channels or volume. There's possibly a limited service mode, but I wouldn't bet on it.
          • Mad_Science
            Sharp TFT-LCD Model No. LQ050Q5DR01 gray screen
            by Mad_Science
            I have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
            03-01-2024, 05:05 PM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • ekozeko333
            by ekozeko333
            🧠 What I’ve Done So Far
            Flashed...
            06-21-2025, 02:48 AM
