LG Plasma 60pz550 has strange greenish rainbow flickering.
  • JeffandPeggy
    • Jan 2014
    • 11
    I have a LG Plasma 60pz550 and yesterday we noticed that, around the perimeter and across the whole screen at times. There's this Greenish, rainbow type effect and it, kind of, flickers a little when the camera shots change. It's really noticeable on a black and white TV show. I say rainbow because it may have a little red to it, but it mostly looks greenish. You can see the picture fine, it's just a quality issue. Is this something I can get fixed or is the TV done? Any info would be, greatly, appreciated.
    The nearest LG service is over 100 miles away from me. Someone told me it was called "Sparkles". One person told me it was a bad T_CON control board. Another guy said to replace the control module and then another guy said defective plasma pdp display. If I knew for sure I'd change the part myself, but I'm getting different answers. No warranty. I'm lost.
  • smai
    • Dec 2013
    • 69
    Re: LG Plasma 60pz550 has strange greenish rainbow flickering.
    hi welcome to the forum
    so are you saying the problem is intermittent or its always there ?
    can you get a picture of what you are describing?
    • JeffandPeggy
      • Jan 2014
      • 11
      I posted 2 videos on YouTube. It's not there all the time. It's sporadic. Shows up in different spots depending on the light.
      In the video, with Sponge bob, you can literally see the effect disappear and reappear so I'm confident that its not screen burn.
      It shows up better on a Black and White TV show (Unfortunately, none on at the moment) Later today I will take a video in black and white and post it to YouTube. You can really see the randomness on a B&W show.
      Here's the links:
      http://www.youtube.com/watch?v=I1YK0jigGzw
      http://www.youtube.com/watch?v=-WUSGb14YUg
      • freakaftr8
        • Oct 2012
        • 3743
        my question is if you were to pause what you were watching with the rainbow effect stay there and not disappear? just from the videos it looks like a voltage is either off for varying going to The sustain boards. usually if it were a mainboard issue or a logic board issue it would be all throughout the screen. and my last question is does it do it when its cold when you first power it or after its been on for a while?
        • JeffandPeggy
          • Jan 2014
          • 11
          If it were to pause, where the light from the picture stays the same, I believe it stays. I'm desperately trying to find a black and white show to record because you can really see it good.
          I could almost swear, when you watch black and white, that it does hit all over the screen just at different times, but not 100% sure. Again depending on the light coming from the picture.
          I did notice, that when the TV is off for an extended period of time (at least an hour) when you turn it on, it DOES NOT do it immediately.
          Actually, Ive been watching it for about 15 minutes and it hasn't done it yet, so it may have something to do with the temperature of the TV
          • JeffandPeggy
            • Jan 2014
            • 11
            Now that I think about it, I'm not sure it is does consume the entire screen. I'm going to have to watch it close to find out. I really need to find a black and white show to know for sure. My eyes get lost in the color. You may have better eyes than mine. It is, predominate, around the perimeter.I'm not sure if the light stays more sound in the middle of the screen and changes more on the outside or not.
            • JeffandPeggy
              • Jan 2014
              • 11
              One Note of interest: On 45 minutes now and hasn't done it yet. I'm puzzled now.
                Someone on here had a similar issue, also 60". Some cold solder joints on the Z-sustain board, ERC inductors... I'll try find the thread
                • JeffandPeggy
                  • Jan 2014
                  • 11
                  Thank You
                  • JeffandPeggy
                    • Jan 2014
                    • 11
                    Almost 2 hours now and still not doing it. I'm confused more than . I thought, maybe, the TV would be as warm or hot as it would get after being on for 2 hours. Strange.
                      If it does occur again, post some pictures of the boards in the TV so the fault can be located.
                      • JeffandPeggy
                        • Jan 2014
                        • 11
                        Tom. Did you see the videos I posted earlier in the thread?
                        Last night,strangely, it didn't do it at all.
                        This morning it's doing it, but at a much slower rate.
                        It's not constant. I'll try to take a picture of it and maybe another video
                          Yes, I did. I mean pictures of the circuit boards inside the TV, if it is to be repaired by yourself - are you confident around a soldering iron?
                          • badabing
                            • Oct 2014
                            did you ever get to the bottom of this as i have a similar sounding issue
                              Like THIS?
                              https://www.youtube.com/watch?v=IsMP...k&noredirect=1
                              See HERE:
                              https://www.badcaps.net/forum/showth...hlight=60PV450
                              • compaqstud
                                • Dec 2014
                                • canada
                                Hey tom66 quick question for you i have a visionquest pvq32vgb which from what ive seen is made by LG.. I have rainbow sparkles all over the screen. I have tested the va and vs both adjusted to sticker specs.. I have looked at the ysus board and it has a VSC tag on the board.. The problem im having is all the pots on the board are labelled VR1, VR5(set on), and VR2 so none of the common labels.. Please help me i bought this tv under the impression it worked and its a gift for my father for xmas.. The sticker states 5.2v/Va 63v/Vs 193v/n.a/-130/130 n.a/160. Sorry to hijack the thread but i cant pm you Tom66.
                                • reessi
                                  ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                  by reessi
                                  The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                  They are black on the right and gradually fade to nothing on the far left.
                                  They start either after 5 mins or up to 2 hours after so annoying for testing.
                                  They flicker continuously very fast! With a slight pause milli-second every second.
                                  Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                  I tested each half by removing the first the left flex from...
                                  06-03-2025, 09:58 AM
                                • DrvLikHell
                                  Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
                                  by DrvLikHell
                                  Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
                                  The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
                                  07-05-2024, 02:54 AM
                                • Jaysean
                                  Acer VN7-591G-70RT Display Flickering
                                  by Jaysean
                                  Hello Badcaps coummunity hope you all are having a bless day,
                                  Hope I didn't post it wrong kinda new at forum site rules and tradition
                                  So I'm dealing with screen flickering problem on my laptop.
                                  I'm not quite sure if it's the display cable or the screen itself that's causing the issue,
                                  so I'm turning to you all wonderful expert on Badcaps for some guidance. Your help is much appreciated!
                                  [Screen Flickering](https://i.imgur.com/xK9vHqc.mp4)
                                  [HDMI port to external display seem to work be working](https://i.imgur.com/snSC24e...
                                  10-27-2023, 10:22 AM
                                • Stasonio
                                  Panasonic TX-PR65VT60 plasma flickering pixels on black
                                  by Stasonio
                                  Hello!
                                  On my Panasonic TX-PR65VT60 plasma, flickering pixels (or subpixels) run uniformly on completely black areas of the image or on a completely black screen (for example, an image with completely black areas, black fill, or hdmi, AV input without a signal). This can be clearly seen in complete darkness at close range, and is very similar to how it is shown in these videos:
                                  https://youtu.be/IgcqC12Wc2U
                                  https://youtu.be/Bfzaw4D2Byg
                                  I repeat that this happens only in completely black areas, otherwise there are no complaints about the image and the operation...
                                  05-14-2020, 08:20 AM
                                • arctor
                                  LG 55uh661v flickering images and lines
                                  by arctor
                                  Hi, I have this tv a LG 55UH661V that show flickering images and lines. I tried to take off one at time the right and the left ribbon cable and put the tape for ask the pin…but nothing working. Or I stop to have picture or still flickering. Someone can help me to understand what pin I have to mask? What I notice the buffering board, the flat cable becomes very hot, I don’t think it s normal, I’m talking about the orange flat cable soldering on the buffering board, both side are very hot. I give you the photo with both the ribbon cable on and a photo with the right off and with the lefts...
                                  06-16-2025, 11:57 AM
