No image on QLED Samsung TV QE55Q85RAT
  • jbsers
    • Jan 2020
    • 6
    • France
    Hello everyone
    I have a QE55Q85RAT TV that no longer turns on - to be more precise, here are the diagnostic elements:
    - when I turn it on, the red LED flashes once, we hear a slight "zz" twice on the motherboard, then the LED flashes twice and this cycle repeats indefinitely and no image
    - taking inspiration from certain forums, I put tape on 4 tracks of the ribbon which goes from the motherboard to the panel and then, the TV still does not show any image but the sound works and the TV responds to the remote control (I turned on the voice guide) - the TV being connected to the internet, I can hear the channels.
    Here are the tests I carried out with the TV running:
    - I tested the voltages on the power supply card, I noticed:
    350V for pin 5 which goes to the motherboard (CNM801 connector)
    46.7V for Vdrv (pins 3,5,7 and 9 of connector CNV901A)
    On the inverter card:
    2.85V for the BLU_ON/OFF pin of the card
    I can find the 46.7v on pins 9,11,13 and 15 of the CNV901A connector
    Having read that the BLU-ON/OFF had to be at 5v to light the LEDs, I unplugged the Motherboard - Inverter cable and put 5v from an external power supply (batteries) on this pin - the panel did not turn on. yet not lit
    I tested the 200 LEDs on the LED panel, all work.
    The diodes on the power supply board work, the 2 capacitors are not bulged (nor are the small ones)
    I lit the panel (front side) with a lamp but I don't see any movement through the transparency of the image.
    I fear that it is the panel which is broken, yet it is only 3 years old and has not suffered any shock.
    I admit that I have reached the end of the diagnostics - does anyone have any ideas on the subject?
    Thank you in advance for your help.
    Have a good day​
  • etbmikenel
    • Dec 2018
    • 17
    • South Africa
    With the LEDs blinking twice you are indeed correct that the fault is located on the panel.
    • jbsers
      • Jan 2020
      • 6
      • France
      Thanks for your reply - do you talk about led panel or Driver card ?
      • jbsers
        • Jan 2020
        • 6
        • France
        I have 2 questions :
        1) do you talk about led panel or Driver card ?
        2) if it's a driver card problem, do you think that it could have a relationship with the rubbon I had to put to have the TV starting ?
        Thanks, regards
        • nomoresonys
          • 12268
          • U.S.
          Post clear straight on pictures of each board and one of the whole back as to see how everything is connected, expose the long thin panel driver boards if obscured from view and post a picture of that also.
          • nomoresonys
            • 12268
            • U.S.
            Could something as simple as what's in this video or something else, checking all the caps is a good place to start, video not in English but self explanatory: https://www.youtube.com/watch?v=Z4D41NujAcE
            • jbsers
              • Jan 2020
              • 6
              • France
              OK thank you - after more troubleshoot actions, I discovered there is no 3,3v on T-COM board - the output of the regulator is close to 0v. I will try changing this board and will tell you.
              Best
                Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
                This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                09-07-2024, 12:10 AM
                09-07-2024, 05:50 AM
              • shlomim412
                samsung ua55es6800 - no image
                by shlomim412
                hi
                having problem with samsung ua55es6800
                tv had backlight on, sound working - responds to the remote control but no image.
                check tcon board - had 12v in but no other voltages present.
                when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                when leaving only left side connected - again no voltages and no image.
                put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                kept trying to block less pins on the left ribbon cable...
                05-15-2024, 05:00 AM
              • Kaar3l
                Samsung QLED QE65Q7FNAT only standby light
                by Kaar3l
                TV: Samsung QLED QE65Q7FNAT
                PSU: BN4400940A
                MB: BN94-12832K
                I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                09-24-2024, 01:35 PM
              • Batata
                Samsung QLED GQ50Q67TGU turns on and off
                by Batata
                Hello everybody,
                my TV has a problem. It keeps turning on and off. The speakers are still working, and I hooked up the TV to my PC, and it recognizes it as a Samsung device. I am able to get a stable backlight when I disconnect the cable(I believe it is called the LVDS cable) that connects the left lower board (which is connected to the "main board") and the right lower board. I have tried a taping method I saw on YouTube, where the CLK cables are taped off. In fact, I proceeded to figure out which pin I have to tape off in order to get a stable backlight. It doesn't matter...
                10-14-2024, 03:45 AM
