transistor?
  • adamp91gvm
    • Jan 2014
    • 699
    • uk
    transistor?
    Where can I get a B20nk50z transistor from
    Re: transistor?
    It's similar to other 20N50 transistors, just match specifications (Vds: higher or same, Ids: higher or same, Qg: lower or same, Rdson: lower or same)
    • adamp91gvm
      • Jan 2014
      • 699
      • uk
      Re: transistor?
      What would u suggest it's popped a hole in it
        Re: transistor?
        I'm not making any direct suggestions - just get out the Farnell catalogue and find the closest match.
        Popped a hole: on a PSU, X-main/Y-main, other?
        • Duncanbest
          • Jul 2012
          • 81
          • Taiwan
          Re: transistor?
          http://www.datasheetcatalog.com/data...B20NK50Z.shtml
          http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
          • adamp91gvm
            • Jan 2014
            • 699
            • uk
            Re: transistor?
            Left board is it the SS that powers the screen
              Re: transistor?
              If it's a Panasonic panel, SC on LEFT, SS on RIGHT, looking from back. SC and SS both sustain the panel (make it light up.)
              • adamp91gvm
                • Jan 2014
                • 699
                • uk
                Re: transistor?
                No its a Samsung 58 inch plasma
                  Re: transistor?
                  Well then SC = Y-Main, SS = X-Main and the idea is similar, they both make the panel light up.
                  • magneh
                    Behringer Eurolive B205D repair - help identifying transistor
                    by magneh
                    Hello
                    Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                    Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                    After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                    I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                    Still, I need to replace this transistor....
                    06-18-2025, 02:34 AM
                  • elsomer
                    help to identify transistor msi ms-15ck1
                    by elsomer
                    hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
                    02-17-2025, 05:30 PM
                  • rddube
                    Help with blowing transistor NAD T752 receiver
                    by rddube
                    I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
                    Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
                    I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
                    09-01-2022, 05:19 AM
                  • amigo744
                    xbox series x u82 5 pin transistor voltages ?
                    by amigo744
                    hello there,
                    xbox series x hdmi u82 transistor 5 pin,
                    can anybody tell me voltages of this transistor in standby and power on mode ???
                    on which pin of this transistor are the voltages ?
                    regards
                    08-16-2023, 08:05 AM
                    AO4601 AO4601L Transistor (Applications Laptops) Datasheet
                    Complementary Enhancement Mode Field Effect Transistor
                    The AO4601 and AO4601L use advanced trench technology MOSFETs to provide excellent RDS(ON) and low gate charge. The complementary MOSFETs may be used to form a level shifted high side switch, and for a host of other applications. Standard Product AO4601 is Pb-free (meets ROHS & Sony 259 specifications). AO4601L is a Green Product ordering option. AO4601 and AO4601L...
                    11-05-2024, 08:21 AM
