Blank SOIC EEPROM and other Stock items
  • Ltank
    • Jun 2013
    • 776
    Blank EEPROMS are cheap. Is it a good idea to stock the a selection of 24c32,
    24C64, 24C128 and 24C256. Rather than buy a Reader/Burner and a SMD adapter to erase them. Suggestions?
    I am working on spare parts stock.
    So any parts that I should stock that have a high failure rate, I would like to hear from you. Rather than make a Thread to ask for different items, it would be easier to make one spot for them. It would come in handy for anyone to access. Tom was very helpful with diode info, he wrote the following in another thread.
    Diodes, in general:
    1N4007, can replace all 1N400x
    UF5408, can replace all UF540x and 1N540x (ultrafast type)
    1N5819, can replace 1N5817,18
    1N5822, can replace 1N5820,21
    UF4007, can replace all UF400x and 1N400x (consider this instead of 1N4007)
    Re: Blank SOIC EEPROM and other Stock items
    I don't replace enough to make it worth it to be honest. Unless you fix hundreds of TVs a month, it would not be worth it.
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      i wouldent stock eeproms,i never really come across these faults that often,only in cello neon make tv's,i have programmed them,but you can get them pre-programmed for about a tenner,not really worth it for a 19"-26" tv,hassle of soldering ,static problems etc...
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      • SidneyCanadas
        93C46 and 93C56 EEPROM
        by SidneyCanadas
        I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
        https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
        Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
        06-14-2023, 01:16 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • dmccul2698
        Pioneer DEX-P99rs "No EEProm " diagnostic code.
        by dmccul2698
        Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
        1). Understand the schematic and check the connections between the EEProm and DSP
        2). Check the functionality of the EEProm
        I don't know if this is the unit's problem but it's a place to start.
        I have little to no electronic experience...
        04-08-2024, 05:32 PM
      • edgarmg15
        Damaged EEPROM on TV Vizio E320-A0
        by edgarmg15
        Hi everyone
        I´m trying to repair a TV Vizio E320-A0 that I found in the street
        The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
        The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
        So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
        11-19-2022, 03:46 PM
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
