LG 42PT350-UD .AUSLLHR Plasma - Dead
  • kevinm34232
    • May 2012
    • 1884
    This TV was dead, I started by replacing power supply and it was still dead.
    If I unplug the main board from the new PS board though, the TV clicked and started to come on, then shut down.
    I found 2 shorted transistors (30F124) on ZSUS board, I ordered and replaced. When I started it back up I heard a pop shortly after and those 2 are shorted again.
    I didn't have the ZSUS screwed down and wondering if while moving it to see if I was getting a pic because I thought I saw the screen glow, may have caused them to blow from losing the ground connection, or if there is another problem. The PS board needed to be screwed down to chassis for it to work also.
    Also the TV will not even try to turn on unless I have the main board disconnected from the PS board, is the main board bad too? Thanks!
  • chaplu
    • Mar 2014
    • 22
    • India
    Re: LG 42PT350-UD .AUSLLHR Plasma - Dead
    hello kevin did you find any solution to it? it seems zsus on my tv having same issue as well i can see two 30f124 but can't tell if they are bad. since there's no physical damage. Any help would be appreciated.
    • k370
      Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
      by k370
      I have a NM-A321 board that is dead, with no power at all.
      When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
      With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
      • +3VALW
      • +5VAUX
      • 1.2VSUS_PWRGD
      • 3VALW_PGD
      • 1.05VAUX_PWRGD
      Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
      The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
      09-23-2024, 11:57 AM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • dokma
      Samsung 50" plasma PS50Q97 with a dead main board
      by dokma
      Hello forum!
      This is my fourth post so I will try to start on the right foot by doing it properly right off the bat. I bought this plasma faulty to play around with. The main board is completely burnt. When I unplug everything but the power supply and the main board and I plug in the power chord I get plenty of smoke from the main board.
      Now, the model of the TV is a bit of a detective work. I couldn't find the model of the TV anywhere on the back cover or inside so I deduced it from the main board codes. SO I THINK this is PS50Q97.
      Now, since the board is...
      07-05-2020, 07:52 AM
    • corrize
      Nikon D5 – dead, power board issue ?
      by corrize
      Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
      When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
      I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
      Now, I try to understand how it works.
      There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
      04-03-2023, 09:13 AM
