RCA rlded3950a-b sound but no video
  • wiseowl9000
    • Sep 2017
    • 4
    Re: RCA rlded3950a-b sound but no video
    Whoops. I misread the resistor value, 47 Ohm not 470 Ohm. I ordered ERJ-P08J470V 47 Ohm Surface Mount Resistors. Will desolder the 470 Ohm ones and replace with the above.
    Usually use the TV without the inbuilt sound, tried using sound and nothing. Not sure when that part of the system failed. Might be related to the power supply issue or might not.
    • wiseowl9000
      • Sep 2017
      • 4
      The repair ran for a month then the same cap blew again. Looks like a fault I hadn't found to repair. It seemed to be running hot over that month too. I'm going to take it in to the repair shop now (having let them know I had a go at fixing it). Could in part be due to my poor soldering skills (poor solder joints).
      Mosfet is burnt out and underside of board is browned (possibly excess resin from soldering the surface mount resistors).
      Still, I had a good time trying to fix it and have spare components to send along with it to the repair shop.
      • d8341
        • Nov 2021
        Originally posted by MrBowtie
        I have a RCA 39 inch led hdtv that made a serious pop noise and picture went black but sound was ok. Thankfully I came across your forums and read for a couple of days now and decided to try and fix it myself. After the pop and video going i unplugged the tv right away. I plugged it back in and tv came on normally but only lasted about 15 minutes and video went black but still had sound. If I turn it off and back on right away it wound not change but if I wait just a minute or two it would come on normal again but only last five minutes and gone again. It doesn't matter if you unplug it and plug in again does it change anything. It seems like you have to wait about 10 or 15 minutes to get it to work 15 minutes at most no matter how long i wait plugged in or not. I also noticed when the video goes black...I can still see video if i use a flashlight near the screen. So needless to say the tv is 12 days over its 1 year warranty "lesson learned lol" and no help from RCA except to ship it to them and they will fix it for $175.00 + shipping and handling. So I took the cover off the back after finding and reading your forums and found a blue ceramic cap blown at C22 on the board. the cap is a 221 1kv. I replaced the cap and tried the tv but the tv does the same thing. So i took the back off again and noticed the voltage regulator " I think it is" I'm a newbie at this lol it's black and has three legs and is screwed to a heat sink. It looks like two legs shorted when the cap blew. Could this cause the problem and how would i go about checking it with a meter? Sorry for the long post.
        Hi, MrBowtie: Thanks for your post!
        I think I am facing the same situation and trying to fix my RCA tv. Are you able to get schematic of this power supply board? What is the value for C22, D5, R44, R45 and that MOSFET? I am going to order these parts to see if I can fix my TV.
        • d8341
          • Nov 2021
          Originally posted by budm
          OK, so the power MOSFET has Source (3) to Drain (2) shorted. The high voltage cap that blew up is for the RC Snubber circuit (the snubber RC network is connected in parallel with Source and Drain of the MOSFET), the cap is connected in series with R44/R45 (R44, R45 are connected in parallel), You need to check R44 and R45. If the snubber circuit failed, the the MOSFET will be damage.
          There is also RCD snubber network (D5, C16, R39 that should be checked) which is connected in parallel with primary side of the transformer.
          You also need to check the MOSFET Gate drive network (R23, R26, R26, R30, D25) for damage. The Gate drive network is connected between the Gate of the MOSFET and the GD (Gate Drive) pin 5 of that SMPS IC. You should check the resistance reading between pin 5 and the one end of the jumper JP9, report the reading. We also need the P/N of the SMPS IC.
          You also need to check the Source resistor (R13?) that has heat shrink tubing on it sitting between the heat sink and the Main 450VDC filter cap, it could have blown open when the MOSFET shorted out.
          So you have lots of components to check, if you don't, you can easily blow up your new parts.
          May I ask what is the part number of IC2? Is it th e SMPS IC you mentioned in post? It seems gone on my power supply board and I need to find out its replacement. Thanks!
          • lotas
            • Jan 2016
            • 4752
            • Russia
            #45
            Ic2 - fan7930
            • soeren
              A2442 - No sound over internal speakers and no video playback
              by soeren
              I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
              All happened after the battery ran out of power overall several days when I was on vacation.
              I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
              07-26-2024, 01:24 AM
            • JRade
              Audio video receiver KENWood KR-V990D,no sound
              by JRade
              When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
              The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
              I replaced the capacitor C303/0.047F, nothing changes.
              I'm asking for help, what should I do next?
              Thanks in advance!...
              08-05-2025, 10:23 PM
            • FrancescoV
              Onkyo HT-R390 no sound output, video output ok
              by FrancescoV
              Good morning everyone,
              I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
              The firmware reported is the following:
              M:1.00/11107BLP
              D:?.??/????????
              O:1.00/11107AL
              The DSP firmware given the question marks seems corrupt.
              On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
              05-11-2025, 02:59 AM
              HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
              This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
              09-12-2024, 02:00 PM
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
