Phillips 47PFL5704D/F7 Audio
  • Ltank
    • Jun 2013
    • 776
    When set is unpluged or losses power the TV turns on but has no audio untill the the volume is turned up to 60% (remote) then it works fine all day. Can be turned off then on OK the volume is fine , goes up down up fine. I was not aware of this untill after the set was back together. The 272217100692 Power supply was blowing fuses. The replacement P.S. was a good price rather than repair the supply. I did not see any problems with the TV Setup Menu
  • samson7point1@yahoo.com
    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
    by samson7point1@yahoo.com
    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
    The player processes the audio signal using two different reference frequencies. The "R"...
    04-30-2024, 11:22 AM
  • i_am_patch
    Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
    by i_am_patch
    Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
    04-30-2024, 08:20 PM
  • MOSSEP
    Monitor Audio RSW12 - Green light but no audio
    by MOSSEP
    Hi
    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
    I have already tried replacing all of the...
    01-26-2025, 08:18 AM
  • grimacelord
    MacBook Air 2337 - Right I/O Board Audio IC - Alternative Replacement?
    by grimacelord
    I'm working on a MacBook Air A2337 that had liquid damage on the right I/O board. I ultrasonic cleaned the board and it all functions except the computer has no audio. I tried reballing the audio IC which is TAS5770AC0, but that did not restore audio. I could just replace the entire board, but I wanted to see if replacing the audio IC would fix it first. Mouser has a similar audio IC in stock which is TAS5770LC0YFFR, but I wasn't sure if it is compatible. I was just wondering if anyone knew if I could use the one from mouser as an acceptable replacement or if I need to purchase...
    12-11-2023, 11:13 AM
  • Piaskos
    Dell Vostro 5490 - no sound, no audio device
    by Piaskos
    Hi, i've got problem with Dell Vostro 5490.
    Board - Mantis CML 18788-1
    Windows says "no audio device detected". The other functions work properly.
    What i've done:
    1. I checked motherboard
    2. I changed audio codec (ALC3204)
    3. I reflashed bios with clear ME
    4. Audio is enable in bios
    5. Both speakers are good
    6. After installing the drivers from the Dell website, the devices visible in the manager:
    - Audio for intel displays
    - Intel Smart Sound Technology...
    01-30-2023, 02:58 AM
