philips 32PFL5405H/12 lcd tv flickering screen
  • anno
    • Sep 2007
    • 140
    • netherlands
    Re: philips 32PFL5405H/12 lcd tv flickering screen
    hopefully this is the good one
    http://www.ebay.nl/itm/HS01G-Manu-ON...dd9459b&_uhb=1
    it has the vertical stripe on left of ic too
    • anno
      • Sep 2007
      • 140
      • netherlands
      i tested the power supply and i think it's ok. I put a 12v bulb on the 12v line and resistor between inv-on and 3.3v line and put the light connectors from backlight in Psu. The light bulb is lit and 12v is 12v . I put the connectors from backlight in and backlight is turning on without flickering.
      also there is 391v on the big cap so PFC is working? so i think the mainboard has a problem?
      the inv-on voltage is stable. I soldered a new tuner in before maybe i did something wrong or damaged something. can`t see anything wrong
      • vinceroger69
        • Mar 2012
        • 6714
        has the flickering only just started after you fitted a new tuner or was it there before fitting?
        • anno
          • Sep 2007
          • 140
          • netherlands
          i don`t know. maybe try to remove the tuner again?
          • Ado02
            Lenovo Thinkpad X1 Gen 10 - Flickering Screen
            by Ado02
            We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the IntelĀ® IrisĀ® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
            The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
            12-16-2024, 02:33 PM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • valvashon
            LG 55UH6150- trouble powering up, then half lit screen (pictures!)
            by valvashon
            The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
            Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
            11-24-2024, 12:08 PM
          • fanaticgames
            Philips 43PUS6703/12 screen flickering intermittent
            by fanaticgames
            Hi guys,
            I have this philips with this defect, I tried cleaning the flats of the t con but nothing changes, is the screen the problem??
            https://streamable.com/0zl6y3
            01-05-2023, 09:19 AM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
