LG 55NANO913NA Purple / Pink Line / Spot
  • Vlad713
    • Jan 2024
    • 12
    • Romania
    I am struggling with an issue on my LG TV, as mentioned in the title - please see the attached photos.
    The display / panel has been replaced in March 2023, under warranty - right before expiring after 2 years of use - due to a bunch of dead pixels.
    Then in a few months the purple / pink line started showing up, however the LG service said that this is not covered by any warranty, anymore, since the original one has expired.
    Recently I have just asked a repair firm to have a look and they have said that the panel needs to be replaced, however this costs about $650, so it's not worth it.
    I have seen a similar issue on plasma panels, under this topic, and was wondering if reflowing the solders will sort this out.
    Thanks,
    Vlad
  • William1967
    • Nov 2017
    • 210
    • Netherlands
    The repair company is right, the panel needs to be replaced. Reflowing does not help and you cannot compare this TV with a plasma TV.
    • Vlad713
      • Jan 2024
      • 12
      • Romania
      Thanks for the quick reply.
      This means that this model has faulty panels, since it got damaged in just a few months, after it was replaced.
      I was hoping for a less expensive repair cost.
      • Diah
        • Feb 2013
        • 6376
        i would say its early to make judgment on panel issue...
        go to this post and download the zip... extract it on root USB and play them direct on yours LG.... show here the result
        • Vlad713
          • Jan 2024
          • 12
          • Romania
          Thanks, Diah.
          I copied the photos and let them play in a slideshow for about 15 minutes.
          Black is black and uniform.
          Also forgot to mention that I did unplug the TV for 30 mins and held the power button on the remote for at least 15 seconds, with no results.
          Then I did a factory reset from the menu and that seemed to help for just a bit.
          • Diah
            • Feb 2013
            • 6376
            you need to do hard reset by sending command INSTOP followed with code 0413 , you can do it from LG service RC or mobile android with IR sender and RC apk or DIY it... all you can find in this forum
            • Vlad713
              • Jan 2024
              • 12
              • Romania
              Thanks Diah, I am trying to get hold of an Android phone with IR and will revert with the outcome.
              • Vlad713
                • Jan 2024
                • 12
                • Romania
                Hi again, just tried the reset with the service remote, it worked, however there is no difference in the image, as it's still showing the pink / purple spot.
                  • 12206
                  • U.S.
                  Looks like you got screwed, seems like a new panel should be under warranty from the time you get it.
                  Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND IT'S ALWAYS IGNORED SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS.
                  • Vlad713
                    • Jan 2024
                    • 12
                    • Romania
                    Not one single day of extra warranty, after the original one expired on the 8th of March 2023, even though the panel was replaced a few days before the warranty expiry, the new replacement had no warranty.
                    So if they change a part right before the standard warranty expires and that part brakes, then you're on your own, eligible to pay for any subsequent repair.
                    The new panel should have had at least 6 months of warranty.
                    Not sure how is it in other countries, but this doesn't make sense from a customer point of view.
                      • 12206
                      • U.S.
                      Don't know if you have this same issue, this is a fix for certain conditions if a tv has the side tabs: https://www.youtube.com/watch?v=7OuPTl9TgUY
                      • Vlad713
                        • Jan 2024
                        • 12
                        • Romania
                        Thanks, I couldn't find anyone to open it, check it and test to see if it has side tabs, however it seems that the panel has degraded a bit more, showing a round darker spot in the middle-right of the screen, so I will have to either change the panel or to buy a new TV when this one dies completely.
                        Most probably I will buy a new one.
                        The LG service representative was adamant that there is no exception that can be made, to repair this one, out of warranty.
                        • Diah
                          • Feb 2013
                          • 6376
                          life with it its not bad... however i don't think panel fault... it could be at the area pink there are push down... this can happen at time the TV on wall mounted,with out water level messurment,, take it down and put it on floor ground on the back straight and smoothly massage the panel surface this could help
                          • Vlad713
                            • Jan 2024
                            • 12
                            • Romania
                            Thanks again, Diah, tried this, as well, with no success.
