Samsung UN50TU8000FXZC shows thin horizontal green line when warm
  • cubytus
    • Jan 2010
    • 11
    Hi to all,
    I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
    I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
    Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It is faint, but knowing it's here annoys me.
    I added a short yellow dash to help locate the green line.
    What could be causing this artifact?
  • Ihandyrepair
    Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
    by Ihandyrepair
    Hi guys
    I just started fixing 4k TV few months ago. so I am still learning a lot
    I got this tv from friend complaint is ghosting or horizontal lines on image.
    never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
    then it started to show the ghosting white image.
    I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
    it has 3 thin small boards at the bottom of the...
    12-05-2022, 04:18 PM
  • arctor
    samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
    by arctor
    hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
    04-26-2025, 05:22 AM
  • richiekotzen
    A1502 - 820-4924-A - light green and then orange without battery - Not turning on - CPU warm,3 beeps
    by richiekotzen
    A1502 820-4924-A, e, no liquid, stop working suddenly. Yesterday, I've plugged magesafe, light green and then orange without battery,3 beeps, not turning on, CPU warm and at some point fan was spining but nothin on screen, .. no chemie.
    12-17-2024, 01:15 PM
  • jimjoe123
    LCD TV Green/Pink screen problem
    by jimjoe123
    I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
    Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
    Then each time...
    02-23-2020, 01:29 AM
  • NConstantinou
    Hp z23n monitor shows horizontal lines
    by NConstantinou
    HI ALL
    i have the above board 715G7282-P01-001-0H3S WHICH SHOWS horizontal lines.
    on power board i noticed 3 capacitors that changed color.
    these 3 capacitors are connected to the positive side of main capacitor.
    i have no schematic and i do not know the values.
    those are c921,922,923.
    c921 is removed.
    how can i substitute.
    thanks...
    03-08-2023, 07:19 AM
