UN75RU800DFXZA FA01 CA02 Compatibility
  • howardc64
    • Jun 2017
    • 634
    Got a CA02 version without all the boards. LCD panel not cracked but unknown condition. Backlight seems to work with LED tester.
    Board sets cost 2/3 price of the TV. Found a FA01 version board set for good price. ShopJimmy doesn't show FA01 CA02 as interchangeable. main board numbers between 2 versions are different but t-con to panel connection appears identical. LCD panel PN is 1 letter different.
    Version CA02
    LCD = CY-NR075FGHV1H (letter H)
    main = BN94-14163F (shopjimmy link)
    Click image for larger version  Name:	IMG_1247.jpg Views:	0 Size:	888.6 KB ID:	3171195
    Version FA01
    LCD = CY-NR075FGLV1H (letter L)
    main = BN94-14004D (shopjimmy link)
    Click image for larger version  Name:	s-l1600.jpg Views:	0 Size:	280.0 KB ID:	3171194
    Anyone know if FA01 main board can be used with CA02 panel?
  • Diah
    • Feb 2013
    • 6421
    i have complete 2 sets boards share same panel Samsung GU-75TU6979 7 and Samsung GU-75TU7979 with wifi &BT tooken from 2 new sets transport damage.
    • EazyBone
      • Jun 2023
      • 1351
      • United states
      What is wrong with it?
      • howardc64
        • Jun 2017
        • 634
        Unknown. Got TV with all the boards removed by prior owner. Need to decide to purchase board sets (expensive) to attempt repair. Samsung TVs with same PN often have different version #. Found a FA01 version board set much cheaper than CA02 version (the TV I have is CA02) which is why I asked if anyone nows FA01 main board (t-con on board) is compatible with CA02 version panel. Panel #s are 1 letter different. Info all on original post.
        • howardc64
          • Jun 2017
          • 634
          Thanks. Just to confirm, you have 2 different model TV (GU-75TU6979 and GU-75TU7979) with identical LCD panel and different boards?
          In my case, panel between CA02 and FA01 differ by 1 letter. Main t-con output connector circuit looks identical. Maybe likely interchangeable but thought I confirm before gambling on the replacement board purchase.
          • Diah
            • Feb 2013
            • 6421
            yes exactly.. if yours panel fine will work straight.... but its gambling not on my boards but on yours screen with out boards 99.9% its rubbish LCD and owner sold the boards
            • howardc64
              • Jun 2017
              • 634
              Owner said LCD is good but why they take all the boards? I have same guess as you LCD is probably rubbish so don't want to pay high $ for board set. Thanks again for confirmation it will work and I'll decide if want to gamble haha.
              • EazyBone
                • Jun 2023
                • 1351
                • United states
                I'd trash that also. Unless you have space you can hold until you get a broken one but that doesn't make sense. Says LCD is good no boards. Shouldn't have picked up in first place
                • JSin21
                  Compatibility of main boards between different variations of samsung MU6100
                  by JSin21
                  Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                  I have Samsung Smart TV UA65MU6100WXXY version DA01
                  Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                  11-27-2023, 04:54 AM
                • Yanleb
                  Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                  by Yanleb
                  Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                  If they are not compatible why did Samsung give them the same part number to begin with?
                  08-04-2025, 11:35 PM
                • cheeky2
                  by cheeky2
                  05-25-2024, 03:27 AM
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • ygorsan
                  by ygorsan
                  🧩 Problem Summary:
                  • I
                  07-28-2025, 08:34 AM
