Just bought this today for £20 so well worth a punt, everything seems to work as I can hear sound and shinning a light on the screen shows that a picture is being produced, there's just no back light, I've checked visually as best as I can all the components, mainly PSU, but nothing is obvious so I ask if anyone know's where to start with this issue, please, I would really appreciate your help, thanks.
Sharp Aquos LC-37LE320E no back light?
Re: Sharp Aquos LC-37LE320E no back light?
good clear pictures of the back of the tv with the cover off and individual pics of each of the boards in the tv -
Here's some photos of the Tv, I've measured the voltages from the red and yellow wires coming out from the top of the power supply, it says on the board that they should be +60v, I'm measuring 24v for all four wires, is this correct or has it dropped from the required 60v?Last edited by Dang; 01-02-2014, 05:16 PM.Comment
Grr... Nothing about this made by Sharp. Just another rebadge! And I thought their LED sets were OK. If measuring only 24V, it sounds like the 24V -> 60V boost converter has failed.
Schematic in SM. 1st result.
http://www.tgohome.com/ServiceManual...&Search=Submit
use 42" schematic as that is same PSU, 37" is different even though your TV is 37".
Check points, power on and out of standby:
- one of C907/C916/C918 on primary/HOT side -- around 370~410V when TV powered up
- voltage across C943 on secondary (1000uF/35V) -- around 24V
- voltage across C945/ on secondary (100uF/160V) -- around 60V
- pin 1 of CN902, red on pin, black on chassis, should measure >2V
Power off, unplugged:
- D985: check not shorted
- R904/R906: check should be shorted (<0.05 ohm) in parallel though meter would show around 1 ohm, this is OKLast edited by tom66; 01-02-2014, 05:46 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
When it comes to powering up the Tv and checking the voltages on the capacitors hot side, do I use a ground screw and then the red probe to positive pin?Comment
For the hot side capacitors please check with the meter probes on each end, i.e. red on positive black on negative of capacitor, you only need to check one of those.
If all those suspects have been ruled out, then it's probably the little 8 pin IC for the boost converter. Hopefully you can buy that on ebay or elsewhere otherwise you'll have to source a PSU.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
If all those suspects have been ruled out, then it's probably the little 8 pin IC for the boost converter. Hopefully you can buy that on ebay or elsewhere otherwise you'll have to source a PSU.Comment
Yes, so if the diode is testing OK, I suspect the chip on bottom for it is bad. Page 207 of that file linked, IC902. Available here: http://www.ebay.co.uk/sch/i.html?_tr...at=0&_from=R40
If you have a scope you can do some checks on the various waveforms produced.
You can also try checking pin 8, Vcc. There looks to be a linear reg circuit which could go bad. Should be around 12~16V.Last edited by tom66; 01-03-2014, 04:19 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
You can also try checking pin 8, Vcc. There looks to be a linear reg circuit which could go bad. Should be around 12~16V.Comment
It is a boost converter.
An inductor is the core of such a converter. An inductor is a device which resists change in current by creating a voltage drop; internally, it works by building up a magnetic field. When current through an inductor is interrupted, a voltage change is produced counter to the change in current.
It's converting the 24V into 60V.
So, the IC902 turns on MOSFET Q991 or Q980 (gate pin goes HIGH to +Vcc), pulling current through the inductor L807. At a certain point, it will hit a time limit (on the order of microseconds) which will turn the MOSFET fully OFF. The inductor wants to maintain this level of current, so a spike of voltage is created. This spike is rectified (made positive, and accumulation only) by D985 and then dumped in Q945/C950. IC902 adjusts the ON-time, as above, to regulate the output to a fixed 60V.
It's reasonably easy to see that if the MOSFET never switches on, because of one fault or another, the output will just pass through that diode and you'll get approx 24V out instead of 60V.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Managed to measure Vcc, it's just over 12v measured from the top of R9120, I believe this to be correct, I can't find Q980 on the board. I managed to find the PDF on the IC in question: , is PIN 7 the offending party here?
Thanks for the explanation by the way, very informative.Last edited by Dang; 01-04-2014, 02:18 PM.Comment
That's quite close to the threshold of not working...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Can you locate Q906 and check voltage on each pin?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Yes, checked from the top again via the resistors attached to it nearest side, they measure: Base @ 14.5v to 14.6v, Emitter @ 13.9v to 14.0v, Collector @ 24.1v to 24.3v, I give you the voltage variances due to their timing, I'd say they fluctuate between those small differences every one second, up/down/up/down and so on every one second, could this be an issue? If it's of any relevance the resistor R9120 measures out at 22.6 ohms.Last edited by Dang; 01-04-2014, 05:50 PM.Comment
Looks like IC902 is bad. There's a 22 ohm resistor between emitter and Vcc, and approx 2V drop, so Iq=90mA... quite a lot for that kind of chip. However, one other thing to check is gate-source resistance of Q980/Q991 in case that is low/shorted.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
OK, managed to test the MOSFET Q991, Q980 is not in place, just blanked off with solder so I guess it's not needed. So looking at Q991 pins down they measure while on: left and right pins show 0v yet the middle is at 24.2v, also while on I tested the resistance of the right pin and it showed 118 ohms, the left -2, conversely, while the Tv was off, the right pin would increase to the point of where I couldn't read it any more, like it was charging up some other component, I guess it's time to order that IC902.Comment
Hi, IC902, is this the same thing?: http://www.ebay.co.uk/itm/2512573176...84.m1438.l2649.Comment
I now have the part but I do need the required tools for the job, from my research it seems my best option is to use a hand held hot air tool and use solder paste, my question is, what are my best options along these lines, what's a good but cheap solder paste and a usable hot air gun? thanks, Andy.Comment
by sam_sam_samThis happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
I am comparing them to a brand new one that I installed
The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
I going to let it run for several days before I remount back on the wall next to the... -
by PNI E.hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
by sefosterI have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
by jdawg99Hi All,
I need some help with this one please. I am attempting a repair on the backlight. TV turns on and flashes the LG logo so stripped it down and found one faulty LED. Replaced it and tested on an LED tester and the strip was good. Put it back onto the PSU and it lasted about 20 seconds before going out again. Same LED had blown. Changed it for another type of SMD one (same voltage) and it seemed fine. Put the TV back together but it was quite dim. Noticed it was in power save mode so turned it off and the screen was bright. Left it on for half an hour only to come back to the... -
by roy.zheroI acquired a free 50” TV. IT is a Sharp LC50LE752E. It does not show a picture and has no backlight, although the indicator light turns blue meaning it has turned on.
When power is plugged in, the indicator light will turn on blue, the backlight stays off and nothing is visible, even with a flashlight. When pressing the touch buttons on the tv nothing happens. When pressing buttons on the remote control the indicator light will blink indicating the IRsignal was received, but nothing happens.
When I hold the force-on-combination it will turn on. It then shows a perfect... - Loading...
