Test any caps that lead back to the chips, usually they are pretty close to the chip.
Vizio V555-G1 stuck on wallpaper; now stuck on V logo
Sure, it's troubleshooting for everyone, in this case we are concerned with the VOLTAGE checking, not if there's a short.Comment
So there's nothing that can be done without removing the eMMC and reprogramming? I don't have the hardware for this so I imagine a new board is my only hope in getting this tv working again.Comment
Well looks bad, probably an eMMC issue, symptoms are there, maybe Diah is right on his theory, check ebay, they might be 25 to 40 bux for a mainboard, which isn't that bad for a 55. if you get one make sure you match up the digits on the white bar code sticker to insure a match.Comment
It makes me so paranoid when there's SPECIFIC model boards but many models used for a single tv. In the case of this tv I've found there are two physically different boards, one having less ribbon connectors than the other.Well looks bad, probably an eMMC issue, symptoms are there, maybe Diah is right on his theory, check ebay, they might be 25 to 40 bux for a mainboard, which isn't that bad for a 55. if you get one make sure you match up the digits on the white bar code sticker to insure a match.Comment
It depends on the serial number as to which board you use. https://www.shopjimmy.com/search.php..._query=V555-G1Comment
Mine is LTMWYILV which looks to be the most expensive and hardest to find 🙄 I did find the following that according to SJ is compatible:It depends on the serial number as to which board you use. https://www.shopjimmy.com/search.php..._query=V555-G1
https://shortcircuitsolution.com/pro...caAlDMEALw_wcB
Yep, that's a match, all the serials that sj lists will work and both these bar code numbers 756TXICB02K040 or 905TXJSA550005, they are interchangeable.Comment
That one is a little cheaper but not much of a warranty: https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw= 756TXICB02K040&_sacat=0&_odkw=+905TXJSA550005&_osa cat=0&_sop=15Last edited by nomoresonys; 01-04-2024, 10:46 AM.Comment
Nice! Thanks for the help! I made an offer on one so we'll see how it goes. I'm a little nervous though because I've read about people replacing main boards in Vizios with this same problem and it didn't fix it... Somehow.That one is a little cheaper but not much of a warranty: https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw= 756TXICB02K040&_sacat=0&_odkw=+905TXJSA550005&_osa cat=0&_sop=15Comment
This is because people buy a working board with a broken screen, and then resell their non-working board to someone else....Comment
You evidently don't know how ebay works, if you are sold a bad board, you get ALL your money back, so the vast majority of seller are NOT selling bad boards on purpose. Plus most people are honest, at least where I come from.Comment
Doesn't matter, if buyer says it was bad, they get a refund, PERIOD. A seller with any sense insures the board.Comment
Was speaking to THIS, where you basically call everyone a crook, I've bought hundreds of boards from ebay and as far as I recall, only received one bad tcon, which was refunded on the spot, that's who's selling things on ebay U.S.Comment
by paulxxxxThe TV stuck at logo and cannot be turned off unless the cord is unplugged.
I was given two main boards and exactly the the same thing happens to both of them.
I have checked all voltages on the connector on the power board that goes into the main board and they all look OK.
There are no signs of damage on any of the 3 boards.
Would someone help me with a pointer to the manual? It's supposedly to be the same as E601i-A3.
Thanks! -
by G33RTPhilips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
It does power up when pressing the power button.
I already try the power button while plugin the plug with no result.
Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
Could this be an PSU or eMMC issue ? -
by Bob1394I have used the search, and am stumped.
My Vizio M65-C1, Vizio logo appears for about 10 seconds then goes off.Power LED blinks 15 times then the TV powers down.
I have read through many threads on the M65-C1 including the following threads. I feel like I must be looking right past the solution to my problem:
https://www.badcaps.net/forum/showthread.php?t=81088
https://www.badcaps.net/forum/showthread.php?t=84241 (not clear on the Eprom actions)
Observations
1) [Interaction] Power turned on via TV button (or remote)... -
Laptop MACHENIKE model L15A RN
Board model V150RNEMB-OD
Stuck on logo no boot, suspect Clean ME
Please help me!...-
Channel: BIOS Requests ONLY!
by justice171Hi everyone,
I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
Thanks in advance!
... - Loading...
