RCA RLED-4275a backlight flash once
  • donnyb
    • Dec 2013
    • 5
    I have a RCA RLED-4275a, the back-light comes on once when the tv is turned on, for a split second. then turns off.
    I have used this forum to replace capacitors on a few Computer Monitors before with good success.
    I have replaced the capacitors which were visibly damaged and I am still getting the same error.
    I am getting sound when plugged into a tv source, and when using a flashlight I can see the image is working fine as well.
    I have a few pictures of the boards:
    [/QUOTE]
  • donnyb
    • Dec 2013
    • 5
    Re: RCA RLED-4275a backlight flash once
    UPDATE:
    Still no real progress, when I unplug the wire that runs from the top right of the bottom picture to the only side-mounted port on the first picture, the back-light flashes on and off when it's first re-plugged in, does this indicate an issue with the controller board?
    Any input is appreciated.
    • RinusB
      • Sep 2017
      • 17
      I know this is an old post but others will find this.
      The backlights flash on and off due to a fault in the leds in the backlights.
      The protection circuit acts immediately to prevent further/any damage.
      When this happens the picture and sound generally still work. The picture can often be seen by using a flashlight close to the screen. Check YouTube how this can be done. Good luck.
      • triplefour
        TCL 75S421 has sound but no backlight not even a flash
        by triplefour
        TCL 75S421
        PSU BOARD: 40-L402H8-PWD1CG
        it shows not even a flash of backlight when powering up.
        but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
        testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
        unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
        i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
        with mb connected, PSON...
        11-17-2023, 09:54 PM
      • Superbee_dad
        Sharp 80” long short flash backlight error - Help
        by Superbee_dad
        Hello Sharp TV experts
        Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
        > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
        > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
        01-24-2025, 11:51 PM
      • ekozeko333
        by ekozeko333
        🧠 What I’ve Done So Far
        Flashed...
        06-21-2025, 02:48 AM
      • corrize
        Nikon D800 camera - flash don’t work and capacitor don’t charge
        by corrize
        Hello, I'm stuck in troubleshooting…
        The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
        In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
        When I press the flash button, it's detected by the system, flash icon appear on LDC display....
        10-01-2022, 10:02 AM
      • crozoki
        Philips 65PUS6554/12 one time backlight flash
        by crozoki
        Hello
        I have Philips 65" TV (65PUS6554/12).
        Problem is when turn on tv backlight flash only one time for about 1 second then turns off and display is dark but sound is there.
        Sometimes TV turns on and work with no problem, had backlight and picture, but mostly Tv wont turn on backlight. Any idea where to start looking?
        Power board TPV 715G9187-P01-008-001S
        Main Board 715G9907-M01-B03-005K...
        09-03-2022, 05:47 AM
