Panasonic th-42pz80b
  • sordids999
    • May 2013
    • 2161
    Ok i bought this tv of a friend claimed it would not come out of standby and after cleaning out about a tonne of dust !
    the next day i tried to turn it on and it worked all day until i unplugged it to go out,again it worked once i left it off for a while but i keep getting 10 red blinks
    any ideas ?
    thanks
    Re: Panasonic th-42pz80b
    10 blinks. Easy fix.
    http://www.youtube.com/watch?v=LjpGKaBt8hg
    You do not need to replace TEA-chip.
    These are fantastic sets. If you are looking for a new TV, I -highly- advise keeping one of these. The picture will blow you away. Though they do eat a lot of power -- around 350W average!
    • sordids999
      • May 2013
      • 2161
      thanks tom where can i get these from ?
        You do not need to replace the TEA-chip.
        • sordids999
          • May 2013
          • 2161
          opps my bad what i meant was where could i get the parts to fix the tv ?
          • vinceroger69
            • Mar 2012
            • 6714
            im using cpc farnell at the moment free postage no minimum order either
            http://cpc.farnell.com/
            • sordids999
              • May 2013
              • 2161
              so do i just replace the 1uF 50V ceramic cap?
                Replace both capacitors on both MC201 and MC301 boards with 1uF 50V electrolytic capacitors. Use glue to secure capacitors to an anchor point, such as the chips. Don't attempt to do work with the board still soldered in, remove it from the board first.
                • sordids999
                  • May 2013
                  • 2161
                  ok thanks
                  • sordids999
                    • May 2013
                    • 2161
                    oh man thats to hard to solder after trying for a few hours so looks like ill order a new power unit
                    thanks for your help anyway
                      If you want, I'm in need of this PSU for some parts unrelated to 10 blinks. I'll buy the broken one off you -- PM me.
                      • sordids999
                        • May 2013
                        • 2161
                        Sent you a pm tom
                        • Andre Gilbert
                          by Andre Gilbert
                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                          11-20-2024, 08:52 PM
                        • jm1234
                          Panasonic plasma TX-P42ST50 - 6 blinks
                          by jm1234
                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                          I checked that board for any obvious faults...
                          05-22-2024, 06:59 AM
                        • Alicat
                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                          by Alicat
                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                          Model number is TH-50PZ85U
                          Power comes on and the red power light stays on solid.
                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                          I also hear a few clicks.
                          I also think my parents said there was a thunderstorm and the TV failed after that.
                          Section 6 in the service manual talks about power and no screen,...
                          10-30-2024, 10:09 AM
                        • CrewmanRedShirt
                          Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                          by CrewmanRedShirt
                          Hello all,
                          As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                          07-13-2024, 11:02 AM
                        • nobbnobb1
                          Panasonic TC-P50U50 Powers Off - 8 blinks
                          by nobbnobb1
                          I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
                          2x DG302 (Q16051)
                          2x RF2001 (D16041)
                          2x 5.6 ohm SMD resistor
                          1x BD8694 IC
                          I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
                          03-21-2023, 08:33 PM
