Philips 37HFL5682L/F7 no standby light, incomplete service manual?
  • jasonbay13
    • Jul 2014
    • 195
    • usa
    picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
    am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board to signal the back-end board that it failed and to not show a standby light?
    thanks, hope someone can provide a quick answer (quick as in low-effort)
    service manual is too large to upload as an attachment so here is a link:
  • alro7779
    Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
    by alro7779
    Hello, guys!
    The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
    09-14-2025, 12:25 AM
  • ChristianBr01
    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
    by ChristianBr01
    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
    04-23-2025, 01:48 AM
  • brithepi2k
    Sony KD-65XE8596 no standby light
    by brithepi2k
    I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
    cheers...
    09-06-2025, 02:22 PM
  • AleMonti
    LG 55EG910V - no power and no standby light
    by AleMonti
    I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
    I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
    The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
    After checking the basics I did the following:
    • I measured all voltages and as expected the only active supply is the 3.5V standby. It
    11-04-2024, 05:02 PM
  • Kaar3l
    Samsung QLED QE65Q7FNAT only standby light
    by Kaar3l
    TV: Samsung QLED QE65Q7FNAT
    PSU: BN4400940A
    MB: BN94-12832K
    I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
    09-24-2024, 01:35 PM
