LG 65ET961HOZA, no video/no audio, black screen
  • Damirget
    • Nov 2023
    • 18
    • Croatia
    Ok, thanks for explanation!
    I will order new T-con board and then I will see if I get something on a screen!
    • Damirget
      • Nov 2023
      • 18
      • Croatia
      Hi Diah,
      I got new T-con board and I got some strange RBG pattern and I could not see all colors on a screen. Please check picture in attachment.
      I tried to connect everything back, but still nothing on a MB and I decide to heat it up with flux and I got picture on TV.
      Although, I can see some white/grey colors on a black, looks like pixels refresh issue.
      Should I proceed with pixel refresh option from settings? I also do have service LG remote….can something be done with that?
      • Diah
        • Feb 2013
        • 6594
        the firmware version on the replacement T-CON didst match your version on MB.
        as you did flux to repair MB BGA try yours original T-CON who knows could come to life.... if not then you need to replacement T-CON downgrade firmware or upgrade it. to let the 2 parts version matched together.
        • Damirget
          • Nov 2023
          • 18
          • Croatia
          Ah…..okey that make sense!
          can you please let me know where can I find information of the T-con firmware and which firmware is now on installed board?
          • Diah
            • Feb 2013
            • 6594
            service menu IN_Start & EZ_ADJ you can check versions and if yours OLED Panel match with T-CON
            • Damirget
              • Nov 2023
              • 18
              • Croatia
              #26
              Thanks Diah!
              Please see attached picture.
              i assume that red “NG” next to Panel matching is not a good sign?!
              • Diah
                • Feb 2013
                • 6594
                Thanks Diah!
                exactly didn't match..
                did you tried yours original T-CON as i suggested??
                the factory Data of the panel and t-con marriage saved on the t-con.spi . swipe it or dump both then compare with HEX EDITOR
                • Damirget
                  • Nov 2023
                  • 18
                  • Croatia
                  #28
                  I didnt tried with original T-con board, because I install everything back!
                  I assume that for dumping firmware from T-con board, I would need programmator, or I am wrong?!
                  can you please share a little bit more details how to do that?
                  • Diah
                    • Feb 2013
                    • 6594
                    since we are going to take out the SPI from boards to have clean dump / write.... it will be better we swipe them.
                    • Damirget
                      • Nov 2023
                      • 18
                      • Croatia
                      #30
                      Hi Diah,
                      can you please let me know which chip is a SPI on T-con board?
                      Are we going to download firmware from chip that I need to take out from the board, or that it is possible with a cable? If it is possible with a cable, do you have a pinout?
                      Thank you for your time!
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • advant
                        by advant
                        02-03-2020, 12:25 AM
                      • kca
                        by kca
                        Hello all ~
                        08-31-2025, 06:38 AM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • Hakuu
                        by Hakuu
                        Hi There,
                        More Details
                        TV Model - LG OLED77G1PUA
                        07-12-2023, 02:37 PM
