new samsung with bad panel @ major retailer
  • Tvbob
    tvbob
    • 204
    You think they would turn it off or take it down. been like that for 3 weeks.lol
    Re: new samsung with bad panel @ major retailer
    Wow. Samsung panels just don't last. LCD or plasma. Have seen quite a few 2012/2013 Samsung plasmas with bad panels too, vertical lines and horizontal lines.
    • truep
      • Aug 2010
      • 373
      Yeah I've seen that several times around here, Always on Samsungs!
      • Glitcher
        • Mar 2013
        • 673
        • USa
        Guess no one will be buying that model once they see it lol.
          09-07-2024, 05:50 AM
        • triplefour
          SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
          by triplefour
          TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
          tcon is built into mainboard.
          Only one cable goes to panel boards.
          there is a cable from one panel board to the other that links them.
          cost cutting measure that results in us having harder time to diagnose.
          removing the link to the second panel board allows TV to stay on with stable backlight but no image.
          used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
          07-28-2022, 07:59 PM
        • NolesFan
          Can LED panels be used from different TV's ( or the internals to the panel )?
          by NolesFan
          I have a TV, ( example ) Sony XBR-75X80G that the LED panel is cracked, does anyone know if we can take the LED panel from a ( example ) Sony XBR-75X80H and plug it in and it will work? Or if the panel measurements is not exact, can we take the internals of the cracked panel 80G TV and mount into the good panel 80H TV? Thank you
          06-23-2025, 09:19 AM
        • KYBOSH
          Samsung UN50TU8000 - Dead Panel Forensic Questions
          by KYBOSH
          I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
          When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
          When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
          Later I checked for shorts on the panel PCB boards but could not find anything.
          When I took a look with the FLIR i noticed the 2 resistors...
          08-10-2024, 08:39 AM
        • Ierwin
          Samsung GU50TU8079U bad panel diagnosis
          by Ierwin
          I was given this Samsung GU50TU8079U that would power cycle after a couple seconds, sometimes a few minutes. The screen would turned cloudy dark with the backlight still lit and then the sytem would restart.
          Its one of the newer screwless Samsung models that I read a lot about panel failures here. It does not have a sperate T-CON board, just one ribon from the mainboard to the panel board and a U-shaped ribbon cable connecting the other half.
          I went through the usual diagnostics:
          unplugged the mainboard -> tv stayed on
          removed the U-Shape robbon ->...
          11-11-2023, 05:09 AM
