Panasonic TC-P50GT25 Power Indicator blinks 4 then 10 times
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P50GT25 Power Indicator blinks 4 then 10 times
    Originally posted by lake effect
    OK so TV repair tech today.
    As suspected: TV had a new twist in that it did not present as typical SC board since not shorted or low resistance but Vsus voltage @205 v with SC NOT plugged in was at 0v when plugged in. Tech called panasonic and they confirmed diagnosis of SC board. SD and SU boards checked out OK.
    Labor will be a little more than anticipated but I went with tech replacing because they warranty and if the SC board does not fix or if anything else wrong with the picture when fired it up they were willing to remove new SC board and stop with initial payment. A little money for insurance that the fix gets the TV back to acceptable standards and then hope this is the only fix needed for a while (hopefully this TV was worth $300+ to fix and lasts for some years....).
    The part is on order (3-5 days) so I will post the final outcome.
    I don't see that as a twist as I think we already discussed it did not have the typical shorted SC2, but what one persons idea of not low resistance is to another comes down to experience.
    Sounds like he may have followed that flowchart where it says above 1k ohms is ok but we already proved the SC was bad.
    he probably did not know what resistance was meant to be at SC2 , hence the phone call.
    Anyway, pity we could not save you money on this one but at least you were'nt taken on a ride.
    • lake effect
      • Mar 2014
      • 17
      Yeah, I measured the resistance at 1.6kohm but Vsus at 0 when SC2 plugged in and Vsus holding steady @205 volts with SC2 unplugged.
      I am $87 into labor that will include install and assume the risk and if it doesn't work or the picture comes up with other issues they are willing to stop and pull out the new SC board and restock. I figure it gives a chance to validate it is the only issue and to evaluate the picture and decide wether to keep the TV or buy new. If all comes out looking good then I have an additional $60 labor plus the new board to pay for so a total on labor of @$150 but gives the chance to see if it truly is the only issue and evaluate the picture. The extra $60 was a "surprise" but at this point it's kind of too late to stop and if it comes up bad then I stop where I'm at and buy new..... This one is really on the fence of wether I should have bought new but to get a comparable TV this repair is @ half the cost of new so the gamble is it lasts a few more years with no new issues.... If it does have more issues then I'll buy new (with 5 yer warranty since they don't seem to last anymore...) and maybe tinker with this one on the side....
      FYI that the tech did say SC board was something I could handle replacement and get firmware update from Panasonic but that replacing the SD and SU cards is a pain to reseat the connectors correctly to the screen and would not recommend me doing that if they had needed replacement....
      • tw2005
        • Oct 2011
        • 6458
        So close, it almost made it below 1K. Must be honest, it does make you wonder the level of knowledge out there with these techs, probably got charged for the tech call to Panasonic. These are Panasonic authorised or just the local shop?
        Well I did try to put forward a convincing argument but you have to make the right decision for you and lets face it if you're not confident we are dealing with 200v etc but you came so far and did all the other tests.
        Never mind, look I like mine and it's a $100 broken TV +100 for boards and maybe a little younger than yours. You should get some good use still.
        He was correct about the buffers, if they are removed can be finicky which is why I'd get you to resistance check installed first to try and leave them undisturbed hoping they were good.
        Once you call the tech, you're in it to the end. So far he's told you what we worked out, that's the painful bit. You gotta cover yourself though.
        I do get a big kick out of seeing someone fix it themselves with a big saving. I've seen some big $$ quoted for repairs like this and no surprise people walk away disgusted and dispose of the TV, which is handy for the enthusiast repairer.
        But I've mentioned earlier, I got in and grabbed some spares for mine but no more Panasonic Plasmas made which I'll miss eventually.
        But i do have a 2009 FHD 46PZ800 mothballed, I think I have a compulsive disorder. Jokes.
        So are they taking the bad board or are you keeping it?
        • tw2005
          • Oct 2011
          • 6458
          I just clicked, if the $87 includes install, what's the $60 for?
          • lake effect
            • Mar 2014
            • 17
            Yeah, at least I was an educated consumer so I don't get taken for too bad a ride. The $60 surprise was over the phone it was $80 +tax for in home visit for evaluation and estimate that applies to labor if I choose to have repaired. What they disn't state when I asked about SC board replacement on the phone is that board replacement standard rate is $199 that the $87 applies towards. They agreed to knock off $50 so that leaves the remainder $60.... I did talk with the manager and let him know this was pretty shady. As I mentioned, at least for the labor charge I get to see if the TV performs well with the new board and if not then they pull it out and I'm done. I am thninking it will perform well and if it lasts a few years then good to go. I am also assuming this TV is still better quality picture than new LED TV's....
            • lake effect
              • Mar 2014
              • 17
              New SC board installed today. TV works fine. No burned out pixels or lines. Put on the scroll bar and Tech pointed a very slight 4:3 burn in on the sides of the display but not obvious that took me a while to see but now that I can see it I will have to try to ignore...
              Tech did not want to mess with firmware update as he stated information he got said that it can cause problems with the A-card so he did not want to mess with it and that it isn't needed. I found the listing on the Panasonic website and the directions has a revision history and it all appears to be updates for Viera Cast and Skype.
              http://shop.panasonic.com/shop/model...nloads&support
              Tech had to take the old card for core charge return.
              I run TV in THX mode with settings I got from Tweak TV and CNET. Tech prefers Game Mode but I find this a little too amped up on color etc.... Maybe I'll play with settings a little...
              So in the end I could have repaired this myself but I learned along the way, saved a little on labor and let the repair shop assume the risk and provide a short warranty. Since I didn't buy the extended warranty I guess I just did with the labor charge.... (justify in my head)
              Now hopefully all runs well for a good long time to come...
              • tw2005
                • Oct 2011
                • 6458
                Sounds good.
                • lake effect
                  • Mar 2014
                  • 17
                  Thanks again for the guidance! This thread was extremely helpful!
                  This extra detail of the sc2 ohm above 1k at 1.6kohm but still faulty and Vsus dropping out to 0 vs stable at @210v with sc2 plugged in may help others.... The transistors metered out ok but I suspect one was going short under load and tripping therefore Vsus ohm out ok but under load not really ok. Also a bonus that I found the blown 1000mf 230v cap on the P board.
                  TV looks great and I'm glad I repaired this plasma. I looked a little at new tv's over the weekend and many options (led backlit) didn't look too good (poor store settings???) and wash out off angle etc. if this lasts a while it's worth it and maybe OLED will become affordable in years to come...
                  Thanks again!!!!
                  • FARM60
                    Sheldon_Clone
                    • Dec 2013
                    • 10
                    Thanks tw2005 for your prior help. I had to drop troubleshooting for awhile owing to caring for 91 year old mom having Alzheimer's dementia. Here's the latest. I bought a DVM instead of using an old analog VOM to get a better reading on voltages. Since the current problem is SOS4, I first checked for shorts on P11 and P35. All good! Next checked 4 blink failure (slide 27). Definitely have 3V at pin 9 suggesting replacement of P board. Since P board is upstream from other boards, does it not make sense to replace it with the hope that it also corrects downstream problems? Of course, if a downstream board presents an increased load owing to a short, it could cause a new P board to go out again. Is there a way of disconnecting all connectors to the other boards and then checking connectors on each board one by one to verify that they are potentially functioning okay? Sure wish there was an obvious problem (blown resistor, swollen capacitor, etc).
                    • FARM60
                      Sheldon_Clone
                      • Dec 2013
                      • 10
                      Oh yes, I disconnected both SC2 and SC20 going to the SC board. Turning on TV causes change from SOS4 to SOS6. Reconnected the SC20 ribbon cable only and now TV goes to SOS7. I suspect this is what is expected if the SC board is working properly. I wasn't sure how to test resistance on the buffer boards per your prior advice.
                      • FARM60
                        Sheldon_Clone
                        • Dec 2013
                        • 10
                        Will start looking into repairing or replacing the P board, but will be looking for any advice prior to this move.
                        • FARM60
                          Sheldon_Clone
                          • Dec 2013
                          • 10
                          Keep forgetting. The resistance across SC2 was ~ 4 megohms.
                          • tw2005
                            • Oct 2011
                            • 6458
                            No, it's not the P board. You have a shorted SC board. That's why you disconnect it from the SC to prove it. Sure it's 4 megohm?
                            They don't always go dead short there but a SOS4 cleared after disconnecting the Sc is a good sign the SC is the cause.
                            Grab the meter and see if Q661 is shorted, that's one that always seems to go if the SC is dead.
                            You could disconnect the SC2, SS11,P35 and the 3 white ribbons that come from the A board and go to the C and SC boards.
                            TV should turn on and stay on, no picture. Could check voltages at PSU then, be a bout 200v at P2 or P11. Don't reconnect those power cables up straight away or ypu'll spike the boards or panel. let sit for 5mins or so.
                            I'm thinking you need a SC, TNPA5081AP if it's a GT25 or AF if G20 but either would work.
                            http://www.moduslinkptstvboards.com/...pa5081&x=0&y=0
                            I'd be asking why they charge so much for an AF repair compared to and AP or the 54" no revision board though.
                            They really should be all priced the same. They all fail the same, parts are the same as far as repair goes and if anything the 54 has more transistors.
                            You do need to check the SD/SU boards and make sure they have not shorted as they can on occasions and will destroy a new SC if they are and you don't check and install.
                            • FARM60
                              Sheldon_Clone
                              • Dec 2013
                              • 10
                              Thank you for the expert feedback. I'll perform the suggested testing in the morning.
                              • FARM60
                                Sheldon_Clone
                                • Dec 2013
                                • 10
                                You were absolutely right. It does seem to be the SC board and Q661 seems to be shorted out. I'l start looking around for a replacement. Is it difficult to swap out this board? Looks like some jumpers to the SM board. Also, once the SC is replaced, do you update the firmware using an internet connection to the TV and using the TV's built in firmware update software or must one get firmware on a flash drive from Panasonic?
                                Hope you will consider sending me your mailing address via email (pfarmer@emory.edu). I'd like to send a token of my appreciation for your excellent help. I've learned a few things in troubleshooting this TV.
                                • abhinav0226
                                  • Nov 2017
                                  • india
                                  #56
                                  my panasonic 42as630 red blinking a lot with an interval of 3 sec but not turning on
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    That's not good, when you start a new thread on that particular model , it'll get discussed there.
                                    • Andre Gilbert
                                      by Andre Gilbert
                                      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                      11-20-2024, 08:52 PM
                                    • Nairolf
                                      Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                      by Nairolf
                                      I have a Samsung DM32D display.
                                      When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                      Here’s what I have tried so far:
                                      1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                      2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                      3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                      From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                      08-24-2025, 03:47 AM
                                    • jean luc ferre
                                      acer aspire v5 571p touching screen cracked led blue of power indicator blinks 1s lighted 3s off.
                                      by jean luc ferre
                                      on this laptop acer aspire v571p the led of the power indicator blinks blue for periods of 1s lighted and 3s off after switch on and this indefinitely.
                                      i tried the hard reset, cmos reset, changing the ram without results.
                                      in order to reach the cmos battery i disassembled the laptop and did several mesures with my multimeter.
                                      The 19v, 5v, 3v are well established after the chip 5v-3v. the following signals : 3d3v_aux_kbc (which supplies the sio chip) and 3d3_s5 are well established also.
                                      but the signals: 3dv3_s0, pw_slp_s3# and pw_slp_s4 oscillate at the same...
                                      11-22-2025, 03:54 PM
                                    • fourroses73
                                      Panasonic Plasma TX-P46VT20 blinks 10 Times
                                      by fourroses73
                                      Hi all folks.
                                      My old Plasma TV blinks 10 Times when i try to start it. Its now 2 weeks that i search like an old donkey on internet and i try everything.
                                      Nothing smell or looks like burned. I think its the A board, but i did not find more infos how search error on the A board. Replace it its not an option: I dont find part for this TV in my country and if i give it to a repair shop its to expensiv...
                                      What i have measured:
                                      Vsus and Vda are ok
                                      Pin1 of connector P7 : 5V ok
                                      Pin1 and 9 of connector P6: 16V in place of 15V but...
                                      12-03-2020, 05:28 PM
                                    • JarzabekPZ
                                      HP Victus 15-fb0104nw not turning on, charging led blinks 3 times
                                      by JarzabekPZ
                                      I'm working on a HP Victus that is not turning on. When power button pressed it only blinks 3 times with charging led. I have checked input mosfets and they are fine. Also all coils are fine too. Battery was empty but I charged it with my lab PSU and laptop started on batery but is not charging. When battery is disconected and only PSU connected it takes 0 current and not starting. What can be the reason?
                                      09-18-2025, 08:16 AM
