Panasonic TC-P46S1 10 Blinks
  • splitcrete
    • Dec 2012
    • 387
    • usa
    Re: Panasonic TC-P46S1 10 Blinks
    Did the set Hum
    • excelsisba
      • Dec 2013
      • 12
      No humming at all, before or after the fix. When it was doing the blinks, it would click on and then the blinks would start.
      • leo25
        • Dec 2013
        • 17
        • United states
        Originally posted by tw2005
        I'd suspect bad SC board but this is from the 2009 troubleshooting guide. Could be almost any board but disconnecting the Sc and getting 6 seems like it may be Sc but i'd follow this flowchart.
        Finding an Sc could be difficult.
        Were did u find this flow chart I followed it and I ended with 6 blinks but I cant do what it says cause I dont have the sides its telling me to go too
        • Andre Gilbert
          by Andre Gilbert
          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
          11-20-2024, 08:52 PM
        • Biruslapio
          Panasonic P58V11B 8 and 12 blinks error "fix"
          by Biruslapio
          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
          04-13-2021, 07:13 AM
        • jm1234
          Panasonic plasma TX-P42ST50 - 6 blinks
          by jm1234
          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
          I checked that board for any obvious faults...
          05-22-2024, 06:59 AM
        • Alicat
          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
          by Alicat
          Stopped by this site trying to fix my parents Panasonic Plasma TV.
          Model number is TH-50PZ85U
          Power comes on and the red power light stays on solid.
          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
          I also hear a few clicks.
          I also think my parents said there was a thunderstorm and the TV failed after that.
          Section 6 in the service manual talks about power and no screen,...
          10-30-2024, 10:09 AM
        • CrewmanRedShirt
          Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
          by CrewmanRedShirt
          Hello all,
          As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
          07-13-2024, 11:02 AM
