LG 50PA5500 stripped...
    Re: LG 50PA5500 stripped...
    Nice fix!
    • Mhewitt56
      • Aug 2015
      Originally posted by tom66
      Ugh, so no chance of any testing being done. Before you install new board, test as such:
      http://www.youtube.com/watch?v=51SZsfH60EY
      I did this test and it comes back with a short, with the top buffer board removed the bottom half of my screen works. I see no damage to the ribbon cable.
        The damage can be very slight. In my case I could only just see the edge with my eye - I had to remove the bezel to see the full extent of the damage.
        • TechGizmo
          • Dec 2014
          • 5
          Tom66 you are correct, hard to see the damage to the ribbon cable unless you know what to look for or you remove the bezel.
          • ugamazing
            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
            by ugamazing
            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
            12-17-2024, 07:05 PM
          • ugamazing
            Apple M1 Boards & Exclamatory Error?
            by ugamazing
            We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
            Has anyone else run into this...
            02-20-2025, 09:24 AM
          • ugamazing
            Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
            by ugamazing
            I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
            08-31-2022, 07:34 AM
          • smic717394
            Mac Air A1466 2012 cpu 300%
            by smic717394
            I bought a mac air 2012 very cheap, because the customer didn't want to fix. After reflowing the ram chips the laptop works fine, I tested the ram and no error. But The fan goes at max speed after few seconds. Running the Apple diagnostic finds an error 4SNS/1/C0000008: Th1H--124. and the cpu usage is like 300%, After disconnecting the webcam cable that on the 2012 model is on the IO board, the laptop, the laptop runs fine, and running the apple diagnostic finds no errors. So the problem is related with the webcam, but I suspect the problem is no the webcam but the light sensor....
            02-06-2024, 03:26 AM
          • hopkok
            Legion 5 PRO, 3 boards, same problem, NM-D562 Rev. 3.0 motherboard
            by hopkok
            Hi friends, last week I got 3 same boards for repair (NM-D562 Rev. 3.0), same problem, power button light up, but motherboard wont start.
            3,3V_alw and 5V_alw, 1,8V_alw and 0,75V_alw presented on all 3 boards, no other voltages. 1,2V missing and if I checked schematic right, I need 1,2V and than can be +3VS and +5VS generated after getting SUSP_N signal from KBC? or vise versa?
            I checked for low resistance on coils, no low resistance.
            Anyone with same issue like me?
            Thanks for any help.
            05-24-2025, 04:21 AM
