kdl 32S2030 no display
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    Hi, I have here a Sony KDL-32S2030 and when i power it on i get a black screen with backlight on and green power light on, I held in the volume up button and could hear the volume go up then a slight hissing sound when it was at max so it would appear the tv is powered on ok just not displaying anything... I have the back off it here now, Anyone any advice?? I've included a pic of the back of the set and the tcon, I was looking for a white fuse labled f1 to test but couldn't see any, Can anyone help me out a bit here... Thanks.. ;-)
  • R_J
    • 9627
    Re: kdl 32S2030 no display
    on the t-con near the lvds cable, next to the board marking D101 is a chip fuse marked `P' (cp1o1p) that is the fuse.
    • Easky15
      • Sep 2013
      • 285
      • Ireland
      Thanks R_J, I'm getting 0.341v on one side of the tcon fuse and 0.000v on the other side?? Is there anything else i can test or does this mean a bad tcon which i need to replace..?? Thanks..
        It means the main board is not sending the B+ (5v or 12v depends on the LCD panel)to feed the T-CON board. There should be switched MOSFET that is turn on to send the B+ to the T-CON board. You can trace those 5 wires on the left of the LVDS connector back to the main board to see where they are connected to.
        • newtothis
          • Mar 2013
          • 1556
          • england
          This with the set on?
          Budm got there before me!
          • Easky15
            • Sep 2013
            • 285
            • Ireland
            Yes mate i get these voltages when the set is powered on and backlight is on..
            • Easky15
              • Sep 2013
              • 285
              • Ireland
              Thanks budm, So does this fault sound repairable or does this mean a faulty main board needing replaced?
              • newtothis
                • Mar 2013
                • 1556
                • england
                Possibly repairable if competent at tracing circuits and soldering.
                  "I'm getting 0.341v on one side of the tcon fuse and 0.000v " I wonder if there was shorted circuit on the T-CON which caused the fuse on the T-CON to blow, and it took out the MOSFET on the main board with it. Please verify that the fuse is still good.
