I have the TC-P65S1 and recently has been acting up. One day i went to turn it on like normal and i heard a couple more relay clicks than normal and the panel wouldn't turn on. The LED on the front would blink 6 times, pause, and 6 times again, ect... The only way I could get the TV to work would be to either unplug it from the wall or hold down the power button. This would then cause the TV to power up like normal. It would then work fine as long as it was powered on. But once off for an extended period of time it would continue to not power up. I was able to locate the service manual for the TV and it stated that the 6 blink was an SC Board failure. So i swapped out the SC board, buttoned it back up and same story. Which brings me to now. I could continue to replace parts until i find the culprit but that doesn't seem like the most cost efficient route to go. Does anyone have any suggestions that might correct my issue? Thanks in advance.
Panasonic TC-P65S1 Power Up Issue
by Ancient1Hi
The TV seem to start ( blinking green) but goes into blinking red. No display and or backlight. Full view photo.
Actions :
1. Disconnected Panel's Right, 2nd, board : TV comes ON (steady green , no blinking red )
1a. You can see in two photos the B/W screen , fading blue "HDMI12" , and the wierd sides of the image, like an old CRT.
Obviously the fault is from or on the Right, secondary board
2. I taped the Flex tracks, ~2 tracks at a time- see Photo. The issue seems to be on the V lines (Assuming Data...09-03-2023, 03:51 AM -
by Ama ChurAfter watching some youtube videos and checking some forums, I'm at a loss. With both ribbon cables connected, we have no image. With the left one pulled out, the screen is black and white, split down the middle. With the right cable removed, it is all black. Backlight is working fine and we have sound and can open applications. We are strapped for money right now and are hoping to repair whatever the issue may be. I think the TV was manufactured in 2012, so I'm aware that may not be possible. Edit: Found a single vertical line of blue pixels on the left side of the screen with one of the ribbon...
by ag63kryHi
Got my Panasonic plasma tv that stopped working suddenly.
Took out the cover all the leads from the powr baord in the middle apart of the main 220AC. and measured Vsus and 15V DC on P2 and P11 connector. Found nothing. Concluded it is the board
Replaced with a second hand one but still the same issue.
Cannot see the 5V or the 15V on the board with or without all the other leads attached.
Here is an example of what I have measured on P6 connector (see the image).
3V DC on pin 6 (STBby 5V and
0,3V DC on pin 7 (F_stdby_on)
No lights on LED,... -
by luis71Hello,i have panasonic TX-43HX580E,I tried to enable 48 bit color,HDR10+ and ALLM and stuck at boot loop screen.I have modified edid.edid.
I have backed up PQ,SPI,and Profile if anyone want
Which usb_auto_update_??.txt can i use to dump firmware?
I would be grateful if anyone could help me to find the firmware for USB recovery.
by imran421I have cf-54 with a strange problem. It charges the battery to 100% but discharge it with in 10 min.
I tried multiple battries not a single one works. Seems to be an issue with CF-54 - Loading...
