panasonic CF-54 battery drain issue!
  • imran421
    • Apr 2020
    • 74
    I have cf-54 with a strange problem. It charges the battery to 100% but discharge it with in 10 min.
    I tried multiple battries not a single one works. Seems to be an issue with CF-54
  • FatalError
    • Jan 2017
    • Ukraine
    I have working, many times checked solution. Before CMOS reset need to discharge battery to 0-5%, disconect main battery (and DVD bay battery if present), then make CMOS reset (without battery), chrarge battery to 100% (preferably in 1 cycle), next 3-5 cycles in use not discharge lower then 50%, after that newer discharge lower then 20%. In such conditions battery works fine.
    • mkdj
      by mkdj
      Mark and model: ASUS X571
      Tests already made:
      - I have removed...
      07-14-2025, 09:16 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • code share
      Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
      by code share
      I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
      Here's what I've tried so far:
      • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
      • Booted successfully on AC power only with the battery disconnected
      • Visual inspection of the battery — no swelling, burn marks, or connector damage
      • Battery
      04-21-2025, 12:50 PM
    • huzo
      HP ELITE X2 1013 G3 weird battery issue
      by huzo
      Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
      01-31-2025, 12:09 AM
    • danielsak
      Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
      by danielsak
      Hello, I have issue with Dell Inspiron 3542.
      Motherboard marking:
      Code:
      PWB FX3MC REV: A00
      The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
      1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
      1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
      10-11-2024, 04:36 PM
