Projector prism glue (Infocus LP290)
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    Got this projector that was having blue and yellow bands along the left and right portions of the projection respectively.
    When I opened it up, I found that the second prism after the lamp wasn't sitting in it's correct place, the glue has come undone. (lamp>prism>mirror>prism>)
    I managed to carefully move the prism to it's correct place, and the picture appears to be correct, but what sort of glue do I need to get to refix the prism? When the projector is tilted backwards, the prism falls out again, so needs to be fixed back in again.
    The glue/compound used before has left a white, hard reside behind it, and seems to have been used on all four edges of the prism/prism housing.
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Projector prism glue (Infocus LP290)
    id use something simple like PVA... if it doesn't work it easily peels back off with no harm done
    • freakaftr8
      • Oct 2012
      • 3743
      Lol pva is the kind of stuff they used in color crt tvs from the 60s and 70s for the glass outer layer. Be careful not to get any on the lens. But yeah that will work
      • tmcw
        • Oct 2010
        • 382
        • Ireland
        Thanks guys...
        Is that the same white stuff (globs of it) we sometimes see holding some larger components to the circuit board (I've always presumed to aid with assembly/soldering)?
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
          Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation P Specification for Upgrade or Repair
          This specification for the Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P51s + ThinkPad Stack Mobile Projector boardview and P51s + ThinkPad Stack Mobile Projector schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
          09-06-2024, 06:11 AM
        • mitsu2k
          The Real Dangers of conductive glue.
          by mitsu2k
          I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
          Here is an experience I...
          04-16-2023, 06:29 PM
        • Valtekken
          Lenovo IdeaPad 3 15ADA05 (model name 81W1) - Trying to flash the correct serial number, machine type and UUID without success
          by Valtekken
          Specs:
          • CPU=AMD Ryzen 5 3500U
          • GPU=(integrated) Radeon Vega Mobile
          • RAM=8GB (2x4GB, a 4GB set is soldered), DDR4; 1x4GB Ramaxel, 2400MT/s, RMSA3310MJ86H9F-3200; 1x4GB Micron, 2400 MT/s, no part number (soldered)
          • Storage=512GB, NVMe SSD, hfm512gdhtni-87a0b
          Hello everyone.
          My issue isn't massive, but I'd like to get this solved since I'm trying to fix a friend's laptop.
          A botched BIOS update by Lenovo bricked this laptop, so I used my BIOS programmer to reflash the BIOS on it and saved it from an early demise. All is good now, but the BIOS reports the S/N, MTM and UUID...
          09-10-2025, 04:14 PM
        • objecttothis
          EVGA 430W PSU Correct voltages but computer won't turn on
          by objecttothis
          I had a desktop form factor mini-server die on me a few weeks ago. Through my initial diagnostics, I was convinced it was the motherboard because when I shorted the Green wire on the ATX connecter, the multimeter gave me all the correct voltages on the various pins of the ATX connector and 5VSTB was also correct. To my surprise the replacement motherboard wouldn't turn on with the case power button either. I threw in another PSU and it turned on right away. This is an 80 Plus EVGA 430W PSU with PN:100-W1-0430. I pulled the cover off and don't see any immediately obvious blown caps or scorch...
          02-08-2025, 11:19 AM
