Samsung LNS3241 no picture, scattered multicolor lines
  • Kelly C
    • Dec 2013
    • 15
    I have a problem with a Samsung LCD TV LNS3241. Current condition: dark screen, backlight on, several multicolored lines, no menu. Utilizing the info in this marvelous forum, I have already replaced four capacitors on the upper right of the power board which is BN96-03057A. The tv now powers up much more quickly, but the picture is unchanged. Any help greatly appreciated.
    Re: Samsung LNS3241 no picture, scattered multicolor lines
    Can you show a picture of the fault?
    • Kelly C
      • Dec 2013
      • 15
      There is no change across inputs.
        OK, can you provide a picture of the back of the set, cover removed?
        • Kelly C
          • Dec 2013
          • 15
          Here it is.
            OK, the top most board, can you get a closer picture of it? Try to get as best focus as possible with minimal glare.
            • Kelly C
              • Dec 2013
              • 15
              The t-con, correct?
                I've highlighted some parts on the t-con.
                For each part, please note down the reference code (IC### or U###), the part number (e.g. LD1117-29), and test the DC voltage on each pin, with reference to chassis ground.
                • Kelly C
                  • Dec 2013
                  • 15
                  Readings from analog meter.
                  Wide tabs match middle of three.
                  From the left:
                  UP4
                  L1117DG
                  2.2
                  4.0 (top to bottom)
                  5.8
                  U14
                  MMC6100B
                  0
                  1 (top to bottom)
                  5.8
                  UP2
                  059I4
                  5.8
                  3.8 (L to R)
                  0
                    I suspect MMC6100B to be your fault, it is a common problem on these T-cons, though I am not certain about the others. Can you verify #1 and #2? Also, any other digits printed on those regulators, below the main part #?
                    • Kelly C
                      • Dec 2013
                      • 15
                      Went to 2.5V scale, same readings.
                      NIKOS
                      L1117DG
                      QA5C11F16
                      MMC6100B
                      25 F16B
                      AK33P
                      059I4
                        Uh, do you happen to be using an analog multimeter? A digital one is preferred, as an analog meter simply doesn't have sufficient accuracy or resolution.
                        • Kelly C
                          • Dec 2013
                          • 15
                          Sorry, that is all that I currently own.
                          I have a few defunct boards, but I doubt I can match that part. Looks like that single regulator would be a significant fraction of the cost of a t-con board.
                            Replacing the T-con might fix your problem, but without checking the voltages accurately, no way to be certain.
                            • Kelly C
                              • Dec 2013
                              • 15
                              T-con fixed it. Thank you for your help!
                              • JJAAMM
                                by JJAAMM
                                Problem
                                07-06-2023, 06:01 AM
                                09-07-2024, 05:50 AM
                              • TR103
                                by TR103
                                - it keeps rebooting
                                01-22-2025, 04:12 PM
                              • Stanley1843
                                by Stanley1843
                                06-29-2024, 11:54 AM
                              • Mgiffune
                                by Mgiffune
                                06-09-2024, 10:28 AM
