how to order caps from digikey?
  • ilikesteel
    • Jul 2012
    • 284
    • usa
    I tried looking up a 2200mf 16v low esr 105c electrolytic cap on digikey's site for a Samsung TV power supply. too many categories' to select info for the cap. any help with searching for such a cap on their site?
    thanks to anyone who can help.
    frank
  • mariushm
    • May 2011
    • 3799
    Re: how to order caps from digikey?
    You select 16v and click apply filters.
    Select 2200uF and click apply filters,
    select mounting type: through hole and click apply filters
    check in stock and click apply filters
    Now you have a small list from which you need to pick capacitors with low esr.
    Normally, you'd look at datasheets at each capacitor in that list.
    However, a nice "trick" you can remember is that usually capacitors with low esr have a high ripple current (which is a good thing) so you can go in that table and click on the arrows by the "ripple current" column and sort from high ripple to lower.
    Now pick from that list whatever you want, but make sure it can fit on your board (look at diameter and height).
    These series are good, low esr capacitors
    Panasonic FM or FR or
    Nichicon HM or HN or HW
    United Chemi Con KZE , KY , LXY, LXZ
    Rubycon ZLJ and others etc
    • ilikesteel
      • Jul 2012
      • 284
      • usa
      Thanks very much for the information. I will give it a try.
      frank
        Here are the spec sheets of the PANASONIC FM/FR/FC series.
        When you find the value, the dimension, and rating you need, all you have to is to type in the PANASONIC P/N in the search box in the Digikey, I.E.: for 1000uF 16V, type in EEUFMC102 then the result will pop up.
        Mouser sometime will have lower price but the shipping charge seems to be higher.
        • ilikesteel
          • Jul 2012
          • 284
          • usa
          Thanks budm and mariushm. just ordered two panasonic fm series caps. very easy to do once you know the procedure. ordered a couple of weller solder tips for my ancient W-TCP-L solder station also. it must be more than 35 years old by now. Thanks for the suggestions.
          frank
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • DrDos
            Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
            by DrDos
            Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
            08-08-2025, 03:16 AM
          • black6host
            Replacement caps for Samson Resolv studio monitor 65A Amp board.
            by black6host
            Good day!
            I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
            I'm going to replace the caps and I'll be the first...
            02-06-2024, 08:22 PM
