Panasonic TC-P42GT25
  • mpj31
    • Dec 2013
    • 19
    After reading many threads and a lot of Google searching I still cannot find where to start on repairing my Panasonic Plasma, Model TC-P42GT25. I turn it on and it has 1 blink... then I hold power and get 10 blinks.
    Best thread I can find similar might be this:
    https://www.badcaps.net/forum/showthread.php?t=28207
    No solution found. Seems as if its probably the A board. Could I then just order an A board on ebay and see how it goes? Doesn't look too outrageously expensive?
  • Gatedmk4
    • Nov 2013
    • 24
    • New Zealand
    Re: Panasonic TC-P42GT25
    What fault is your TV showing? if you send more diagnostic information we can help you a bit more. Every repair is different.
    • mpj31
      • Dec 2013
      • 19
      Sorry to be more specific. The TV does not turn on and I do not get picture, I do however hear a couple clicks as I have always heard, whenever I turn it on, and then the screen remains black. I do get power to the TV. The LCD red power light just blinks. "I turn it on and it has 1 blink... then I hold power and get 10 blinks."
      Does that help?
      • Gatedmk4
        • Nov 2013
        • 24
        • New Zealand
        OK so I assume you are talking about your power LED on the front of the TV. It lights up then goes to 10 red flashes?
        • tw2005
          • Oct 2011
          • 6457
          might pay to check out the SC board and see if there's a short across SC2.
          The other thing i've tried with A-boards is disconnect all power from the SC, SS and c boards, disconnect the white ribbons from the A-board that go to the Sc and c boards, power up and see if it's still SOS1.
          On the 2010 model I tried it on it , the a-board started normal with no error blinks.
          let the power bleed off a while before you reconnect the SC,SS and c boards. you can spike them especially the c boards. I killed a samsung panel once spiking those c boards or the samsung equivalent of them.
          could always check with a meter to see what residual voltage may be still stored on the PSU.
          • mpj31
            • Dec 2013
            • 19
            I've never done any electronics repair... most I've ever done is built a PC. I think I understand all this and will try tonight and see what happens. I do have a meter, not sure exactly what to do with it.
            And yes the LED light on the front of the TV flashes 1 time red on a constant basis. If I hold Power button it then does 10 flashes
            • mpj31
              • Dec 2013
              • 19
              Well I got it open. What is next?
              https://www.dropbox.com/s/dwvhb7807j...2016.22.34.jpg
              • tw2005
                • Oct 2011
                • 6457
                Well, might as well see if it's a genuine 1 blink. I was giving it a bit more thought, chances are it is but try this anyway.
                I'm a little unsure about the layout of this model , 2D or 3D?
                Does it have just the following boards, SC,SD,SU,PSU,SS, C1,C2 and A-board?
                If so, try
                Disconnect,
                power at SC2 which in the photo it looks like you have.
                power at SS11
                At the PSU disconnect P35 , this feeds the C boards at the bottom of the panel.
                disconnect the three white ribbons at the A-board.
                Power up and see if 1 blink still.
                Avoid reconnecting the cables straight away as there will be voltage still present from the PSU, you don't want to spike the c boards, can blow the panel, I have on an old samsung.
                A multimeter would be handy to measure any residual voltages, about 200v at the Sc/SS boards SC2/SS11
                I have had an A board which had a sos1 due to corrupted eeprom on yours it would be IC9304 which you can order programmed but I have no way of proving that would be it or not.
                The other common fault is the SC board shorts at SC2, shorts the PSU and you get SOS4, but I've read SOS10, maybe SOS2, 6 & 7.
                • mpj31
                  • Dec 2013
                  • 19
                  ill Try What you Recommended And Get Back To You. I Will Comment That I Plugged Sc2 Back In And Booted Up Tv TO Make SUre I Could See Lcd Blinking And I Got SOS4 Instead Of 1.
                  On My Phone, Hence The Odd capitalization Of Text.
                  • mpj31
                    • Dec 2013
                    • 19
                    Ok well I did what you told me by disconnecting everything and we have something to report at least. Not sure what you were looking for, but I ended up getting a steady red LED. What should I try next?
                    https://www.dropbox.com/s/ssyaxpt4x3...2013.16.22.jpg
                    • tw2005
                      • Oct 2011
                      • 6457
                      Ok, The sos4 you reported is the key I believe, check resistance across SC2 and report back, expecting zero ohms or very low.
                      The sos4 suggests shorted PSU, usually it's the SC board.
                      The fact the led went normal with everthing disconnected from the A board proves the A board is good.
                      • mpj31
                        • Dec 2013
                        • 19
                        Ok I plug everything back in that you had me unplug earlier. Then you want me to test resistance of SC2 while the TV is plugged in and turned on?
                        I have a multimeter... where does the red end go and where does the black end go. Sorry, learning here...
                        Edit:
                        Ok so without turning the TV on and everything still disconnected I did as follows and touched the two metal parts. Shown in pic below is somewhat what I did although the red is not touching in my picture.
                        I get a reading of 193.~ on the multimeter set to 200 setting.
                        https://www.dropbox.com/s/f5e9cj30km...2017.40.19.jpg
                        I see another thread here:
                        https://www.badcaps.net/forum/showthread.php?t=30351
                        It looks like they actually removed the board and tested underneath... I'm trying to avoid having to remove anything at this time...
                        Edit 2:
                        From another one of your posts you posted a link to a troubleshooting guide. I was skimming through it and tested resistance of VFG and VFO and only get about 81K instead of recommended 190K. I tested VFG and 5V_F and indeed got 2.6K as recommended.
                        • tw2005
                          • Oct 2011
                          • 6457
                          With TV off, SC2 disconnected, measure resistance across the pins on the SC board at SC2 or set to diode mode / continuity . Continuous beep or low ohms or 0 ohms will be bad.
                          I don't know what you are telling me with 193. resistance or voltage.
                          I you could give me the part numbers and version of the SC/SM boards. usually a white sticker on the boards or could be a two letter siffix stamped . eg TNPA5081AH , TNPA5086AC ?
                          I forgot the 42" have combined SU/SD, only touched the 50" versions
                          Also a full photo of the layout of all the boards in one shot.
                          You can attach photos, go advanced, manage attachments, upload the file.
                          Max res is 2000 x 2000,
                          • mpj31
                            • Dec 2013
                            • 19
                            Hopefully you dont mind me linking to my dropbox so I don't have to readjust the pictures. Here are some high-res shots.
                            Again when I test resistance as you described with TV off, with the multimeter in the position shown in picture 2, I get a reading of around 193.~.
                            To confirm what you probably already know this is a 42 inch 3d television purchased around Sep 2010. Lot of money spent on this to see it die in 3 years.
                            https://dl.dropboxusercontent.com/u/...2/TV%20001.JPG
                            https://dl.dropboxusercontent.com/u/...2/TV%20002.JPG
                            • tw2005
                              • Oct 2011
                              • 6457
                              Well i don't know much about 3D, interesting there appears to be no extra boards from the standard 2D or at least i can't see any.
                              So I can't see the meter in the shot but if it's 193 ohms that would be bad although usually they go pretty much short cct.
                              Generally you can see around 300k ohms at that point or if you measure it and remove the leads then put them on again straight away it can switch to measuring Meg ohms. Swapping the leads across can give different results. what ranges do you have to chose on the meter?
                              If you power up without the Sc2 connected, does 4 blink go and you have 6 or 7 blinks?
                              • mpj31
                                • Dec 2013
                                • 19
                                You want me to connect everything except SC2 and give it a shot?
                                • tw2005
                                  • Oct 2011
                                  • 6457
                                  yes, hopefully no sos4 but i think it will be sos7
                                  • mpj31
                                    • Dec 2013
                                    • 19
                                    Yes, sos7 is what I got, assuming I got the ribbons back in correctly. my meter goes 200 to 2000k
                                    • tw2005
                                      • Oct 2011
                                      • 6457
                                      Ok, I know we may seem to be going in circles but reconnect the Sc2 to re confirm the SOS4, hopefully. I'm quite confident the Sc is bad just a little surprised it's not dead short , 193 ohms is way too low, you could set the meter to a higher range and reconfirm 193ohms, I don't know the quality of the meter you have.
                                      as for those resistances for VFo etc, I'll need more info on where and how you measured those whether we're talking at the Sc or the Sm or at the SC withthe Sm connected etc.
                                      Do you know what guide you used?
                                      I had a quick look at another model with a SM and the pinouts for the buffer resistance tests appear to be different to the SD/SU setup.
                                      You'll have to test the buffer resistances too before replacing the Sc just in case they have shorted too. In most cases it appears they survive but not always and I have been caught out being lazy on this and blown up a new SC much to my disgust on a 50"
                                      • mpj31
                                        • Dec 2013
                                        • 19
                                        The guide I used was posted by you in another thread back in July or so. I can't seem to locate it anymore. It said to do a few things and I said "Hey, that looks like mine on the same board, so lets see what happens". It then proceeded to say to unscrew some things and I did not go as far as that yet.
                                        As far as reconnecting SC2...
                                        Without it connected I get about 314 on a 2000 setting, 192 again on a 200 setting.
                                        Upon reconnecting SC2 I'm back to SOS1, not 4. I'm not sure why I saw 4 at one time...
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • Vebririon
                                          panasonic TX-P50V10E 6 blink led problem
                                          by Vebririon
                                          I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                          Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible โ€” so please forgive any odd phrasing.
                                          I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                          05-17-2025, 10:16 AM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here๐Ÿค”?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting ๐Ÿ˜‚.
                                          11-20-2024, 08:52 PM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
