Panasonic TC-50PS14 10 blinks
  • kyij
    • Jul 2013
    • 45
    I currently have a Panasonic (TC-50PS14) tv and the power (red light) blinks 10 times and repeats. People on the web say it is the A-Board, but I am not sure where they are getting there info and just would like to confirm.
    Also I would like to be pointed in the right direction on tips on how to test major/ common problems which something like the a-board.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-50PS14 10 blinks
    10 blinks could be a number of things. I had an A-board cause a 10 blink recently because it blew a couple of logic buffers on the board shorting the P5V line.
    But i have read along the way shorted SC/SS boards have also caused 10 blink.
    Try this link and download, it's a training guide for your series of TV.
    pages 57-60
    https://www.badcaps.net/forum/attach...7&d=1372477292
    • kyij
      • Jul 2013
      • 45
      I am just taking a gander at the pdf now and it looks very appropriate to be able to help me diagnose this later tonight..
      Are there these types of references for most tv's out there or at least where did you goto to find it? Thanks a lot.
      • kevinm34232
        • May 2012
        • 1884
        I had 2 shorted IC's on the A board which was shorting out the SUB9V line causing the 10 blink code.
        • tw2005
          • Oct 2011
          • 6458
          https://www.badcaps.net/forum/showthread.php?t=25836
          http://www.tgohome.com/ServiceManuals
          http://elektrotanya.com/
          • kyij
            • Jul 2013
            • 45
            Alright, much appreciated for the links, will get much use out of them..
            Anyhow, the testing says it is the sc board.. is this a common part to go out? It is neat coincidence that it also has to be one of the most expensive parts too.
            • tw2005
              • Oct 2011
              • 6458
              SC board failures are fairly common these days.
              Have you tested anything on the SC to confirm it's faulty? Try resistance at SC2 Vsus, the P15V and P5V lines that go in at SC20.
              • kyij
                • Jul 2013
                • 45
                SC2: 3.8 Ohms
                P15V:
                P5V:
                I could not figure out where the P15V and P5V are.. I see them in the diagram from the pdf you provided but can not tell if they are certain pins or connectors elsewhere near it.
                • kyij
                  • Jul 2013
                  • 45
                  After looking some more, I found pages 30-31 to test it..
                  • kyij
                    • Jul 2013
                    • 45
                    Alright well I did the test of pin 3 and 5 on SC42 and I believe the seem fine. (Rec for P3 was 2.9K, I got 3.03K & for P5 rec was 5.7K ohms and I got 5.88). Obviously this does not indicate a good board but does not lead me to know it is defective for sure.
                    • tw2005
                      • Oct 2011
                      • 6458
                      If it's 3.8 ohms on SC2 then that's the fault basically it's shorted.
                      I was expecting Vsus short which is what I've read on occasion for a 10 blink. For my TV which is a 2010 model, the SC blows and shorts Vsus producing a SOS4 or PSU fault code but that's because the PSU is being shorted.
                      I'd also test the SD/SU buffer boards as well before you fit a working SC board to them just in case they are shorted as well so you don't run the risk of blowing a good SC board.
                      Not sure how you'll go finding a SC though for this model, they seem scarce.
                      • kyij
                        • Jul 2013
                        • 45
                        Sorry but one last addon until you reply- I also tested the SD/SU (or at least tried) as I am not getting a reading from the pins the manual wanted on PG27/28. I would get results for other points but not those ones specifically..
                        • kyij
                          • Jul 2013
                          • 45
                          I have found a SC that recently popped up - $200 is a pretty good chunk but looks like guy is parting out his old tv due to cracked lcd - so I am attempting to offer..
                          Also can you just confirm I am testing the SC2 correctly, I will upload a pic and now the resistance wants to say .7/.8 - I am new to the whole testing pieces resistances, etc - before I would just test voltages and give it a green light / red light and decide on what to part with lol ..
                          • kyij
                            • Jul 2013
                            • 45
                            Anyhow, I was thinking - if it costs that much for the part.. is it really worth it?
                            I only paid $20 for this tv and it has a good screen but if like you said - another board is shorting it out, I could be out the cost of just buying a working 50" at least I feel like so..
                            • tw2005
                              • Oct 2011
                              • 6458
                              Looks dead short. no way I'd pay $200 for a used SC from a cracked screen which may also mean that SC may be bad too.
                              • tw2005
                                • Oct 2011
                                • 6458
                                Your meter is not good enough I'm afraid. looks like it stops at 2 Mohms (2000K). What they show is 2.1 Mohms. So if your meter reads nothing and I assume not 0.0 ohms but shows O.L. ( out of limit) then You could assume it's not shorted and the resistance is greater than 2 Mohms which is just fine.
                                • kyij
                                  • Jul 2013
                                  • 45
                                  Well bottom price he is willing to do is $165 (including shipping) as he even stated he knows it is in limited supply.. And I know I need a better DVM, do you recommend any certain ones?
                                  Also - it is not reading OL nor 0.0, it does not read. It shows just as if it nothing is connected (1__._) - Is the SC suppose to be connected while testing these?
                                  • kyij
                                    • Jul 2013
                                    • 45
                                    Also I saw in past someone sold a broken SC board for $50 so I believe I can recoop some even if I have to pay this.. and like I said, I only have $20 in the tv - $180 for a 50in is not too bad.. just the problem is that if the other boards could possibly be bad too.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      I'd say that's the same as out of range. There's plenty of other guys which would have a better idea of what's out there.
                                      I have a 20 year auto ranging fluke 77, very basic but easy to use and accurate.
                                      I saw a listing on Ebay for repair at $110. What we really need is some people to have a go on this forum at repairing these boards.
                                      $50 for a dead board, that's good money, suggests they must be reasonably cheap to fix for someone to pay that.
                                      I guess if the Sc is the only bad part then I guess $200 all up is ok. That's what my 2010 50" set me back to get it going. $100 for the TV and $100 for boards but I got lucky as I got a full set of boards for that. But that was before my SC board started to dry up and go up in price.
                                      I've since fault found my faulty ones and did component repair- very challenging with plenty of mistakes and blow-ups along the way.
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        http://www.lcd-plasma-parts.co.uk/in...roduct_id=2202
                                        I have received shorted SC & SD boards out of a full set from this guy before but I got my money back, that's always the risk that they are not always tested
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • CrewmanRedShirt
                                          Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                          by CrewmanRedShirt
                                          Hello all,
                                          As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                          07-13-2024, 11:02 AM
