LG Plasma 60pk950-UA no picture or sound
  • clubberlange
    replied
    Re: LG Plasma 60pk950-UA no picture or sound
    Originally posted by tom66
    I made a mistake in what I said above. The YES/NO are the wrong way around.
    Seems like the case "YES" applies to you. So try with only one buffer at a time. The Y-sustain doesn't need replacing.
    These LG Y-buffers seem to be a common fault, seen several with this failure recently.
    When you say isolate the buffers, do you mean remove the p106,p206 connector that jumps from one board to the other?
    replied
    Voltages good when buffers isolated?
    NO:- Repair/Replace Y-sustain. Limited repair information available, no schematics, so replacement is advised, although some basic tracing can be done.
    YES:- Replace Y-buffer(s). (Generally considered non-serviceable due to construction.) Locate which board is causing the fault. To do this try plugging in only one board at a time. There is a YB TOP and YB BOTTOM. Remember to isolate the connection between the two at all times. Check voltages. If the isolation of one board causes the voltages to come up, replace that board. (The panel may or may not work with the board removed. It could display half an image, no image, or just strange patterns.)
  • clubberlange
    replied
    OK, we're close. It is either the Y-buffers or Y-sustain.
    At this point please undo both connectors P104 and P105 on the Y-sustain board (refer to document for locations.) These connect to the buffer boards. Leave all screws in place. Then power on set and check these voltages. Are they as they should be?
    YES:- Repair/Replace Y-sustain. Limited repair information available, no schematics, so replacement is advised, although some basic tracing can be done.
    NO:- Replace Y-buffer(s). (Generally considered non-serviceable due to construction.) Locate which board is causing the fault. To do this try plugging in only one board at a time. There is a YB TOP and YB BOTTOM. Remember to isolate the connection between the two at all times. Check voltages. If the isolation of one board causes the voltages to come up, replace that board. (The panel may or may not work with the board removed. It could display half an image, no image, or just strange patterns.)
    Sorry, kinda jumped the gun on that one. If I unplug p104,p105 the voltages are good. ShopJimmy has the Y-SUS and buffers in stock. Would you recommend replacing the buffers too?
    replied
    At the moment, as I said, the power board is not under consideration because the voltages it is producing are all nominal. If this was not the case then I would suggest checking the power board, but it's working fine.
    Be very careful when plugging in Y-sustain again. Wait a few minutes for Vs to drop below 50V before connecting it.
  • clubberlange
    replied
    Originally posted by clubberlange
    -Vy jumps between 10v-40v
    Vsc jumps between 10v-30v
    If I unplug p113,p114 and take the y-sus out of the equation my voltages on f801,501,301 are good. When the Y-SUS is connected my incoming voltage to the power supply drops to 60v.
    replied
    Last edited by tom66; 12-03-2013, 12:06 PM. Reason: fix silly error/wrong way around
  • clubberlange
    replied
    For now, since the Vs and other voltages are present, the power board is not currently suspect. Please check the -Vy and Vsc first.
    replied
  • clubberlange
    replied
    OK, that's good.
    See attachment.
    With TV OFF and UNPLUGGED:
    - Disconnect the blue highlighted cable, by pressing each clip gently and pulling backwards with minimal force.
    - Place a wire link between the two holes marked in red.
    Then plug TV in and turn on if it is in standby.
    You may or may not see test patterns, but if you do, it indicates the main board is bad (not this board... the board with HDMI etc.)
    I was doing some more research on here and I found a block diagram for the 60pk750 with the 60r1 panel. Since it has all the same boards and panel as mine except for the main board am I to assume the voltages will be the same? If so I took some measurements on the power supply. f801,f501, and f301 only read half of what they should according to the diagram.
    VS=201.6
    VA=59.6V
    M5V=5.15V
    17V=17.17V
    STBY=5.15V
    F801
    stby 0v
    run 174.7v
    F501
    stby 0v
    run 174.7v
    F301
    stby73.8v
    run 174.3v
    replied
    Luktech is probably not correct. It is most likely not involving the main board at the moment. More testing is necessary.
    At this point, I am going to assume you have a PDP60R1 panel, but please confirm this by looking at the sticker with voltages on it, it will be marked something like "LG Electronics PDP60R1##### Made in KOREA 2010.09.03".
    Please refer here:
    http://tgohome.com/ServiceManuals/?d...h=Submit+Query
    On the 5th page it instructs you on how to test the Vsc and -Vy voltages. Please do so and compare to the label on the plasma panel.
  • clubberlange
    replied
    Originally posted by luktech
    since no picture and no sound. The mainboard is bad
    This is the only board I am having trouble finding. Everyone is out of stock.
    Is there someone on here that can repair this board?
  • luktech
    replied
  • clubberlange
    replied
    OK, that's good.
    See attachment.
    Still nothing
    replied
    OK, that's good.
    See attachment.
  • clubberlange
    replied
    ok, the top right connector on this board has two pins at the bottom marked vs
    https://www.badcaps.net/forum/attach...2&d=1386049781
    with the red probe of the meter touching vs, black probe on chassis and meter on highest dc range (or autoranging) measure the voltage on the bottom most pin with the set in the fault condition. What do you see?
    The ratings for vs, va and other voltages are printed on the panel sticker which has lg electronics logo and pdp60####### markings.
    201.6v
    replied
    OK, the top right connector on this board has two pins at the bottom marked VS
    With the red probe of the meter touching VS, black probe on chassis and meter on highest DC range (or autoranging) measure the voltage on the bottom most pin with the set in the fault condition. What do you see?
    The ratings for Vs, Va and other voltages are printed on the Panel Sticker which has LG Electronics logo and PDP60####### markings.
  • clubberlange
    replied
    OK, at this point, you'll need a digital multimeter. Do you have one, or can you borrow one? An analog multimeter will not suffice unfortunately.
    Yes I have one.
    replied
  • clubberlange
    replied
    OK, on this circuit board, there is a light (logic board)
    https://www.badcaps.net/forum/attach...4&d=1386049781
    Do you see the light glow or flash when the set is powered up?
    Yes. It flashes once, then a real quick flash. A few second pause, then repeats.
    replied
  • KYBOSH
    Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
    by KYBOSH
    Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
    No picture but you hear the TV static (white noise) playing loud and clear.
    The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
    But it seems they didn't get too far and just left it.
    When I first took a look I was amazed at how pristine the inside looked.
    Its as if the TV had been in a time capsule.
    Caps looked like they were just pulled off the self.
    Copper coils had no sign of corrosion on...
    02-01-2023, 11:10 PM
  • TR103
    by TR103
    - it keeps rebooting
    01-22-2025, 04:12 PM
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
  • Ierwin
    by Ierwin
    05-13-2025, 03:31 PM
  • jchang
    Samsung UN70NU6900F no picture and no sound
    by jchang
    Hi all
    I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
    Symptom:
    No picture no sound.
    When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
    No sound at all.
    What I tried:
    1. I tried unplugging the left or right ribbon...
    01-09-2023, 06:28 PM
