Bush idlcd32tv22hd
  • anotherdude
    • Feb 2013
    • 488
    • uk
    Bush idlcd32tv22hd
    Just picked up this bush tv guy said it sometimes turns on then other times it doesn't and the standby light goes off
    It powered on when i got there and now the standby light goes off after a few seconds
    so assuming it's a 5v stby problem, bad caps maybe?
  • ChristianBr01
    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
    by ChristianBr01
    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
    04-23-2025, 01:48 AM
  • SkishyIshy
    Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
    by SkishyIshy
    Hey All,
    I have a Sony 65x900f that I purchased cheap because of a no-power issue.
    I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
    I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
    03-17-2021, 11:44 AM
  • AleMonti
    LG 55EG910V - no power and no standby light
    by AleMonti
    I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
    I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
    The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
    After checking the basics I did the following:
    • I measured all voltages and as expected the only active supply is the 3.5V standby. It
    11-04-2024, 05:02 PM
  • Kaar3l
    Samsung QLED QE65Q7FNAT only standby light
    by Kaar3l
    TV: Samsung QLED QE65Q7FNAT
    PSU: BN4400940A
    MB: BN94-12832K
    I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
    09-24-2024, 01:35 PM
  • jasonbay13
    Philips 37HFL5682L/F7 no standby light, incomplete service manual?
    by jasonbay13
    picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
    am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
    12-01-2023, 09:55 PM
