phillips 42pfl5609/93 no standby
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: phillips 42pfl5609/93 no standby
    ill report back after i get parts.
    thanks heaps for all your help budm.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • corrize
      A funny fuse story – Lumix LX100 II
      by corrize
      Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
      I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
      The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
      There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
      And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
      10-19-2023, 09:58 AM
    • jesterace
      Samsung UE46ES8000 Blown fuse but no other signs of short
      by jesterace
      Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
      09-11-2024, 03:14 PM
    • jshhh
      Help replacing fuse on my Mimaki CJV300-160 vinyl printer
      by jshhh
      Hi guys,
      I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
      How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
      Anybody know how to remove this type of fuse?
      (The fuse is toward the bottom of the image labeled F2)...
      06-17-2025, 01:35 AM
    • Babbar
      by Babbar
      04-12-2024, 01:12 AM
    • fharris1977
      Vizio D50u-D1 Dead Set No Standby
      by fharris1977
      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
      12-28-2023, 10:25 AM
