RCA 46LA45RQ has no picture
  • Phydoux
    • Aug 2012
    • 83
    I just picked up another lcd tv that has some issues. When I plug it in the red power LED comes on. When I hit the power button the LED turns blue and the screen looks like it tries to come on. Then the screen goes black like it shuts off but the LED is still blue. Is the LCD screen bad or is it an internal component that's bad?
    Re: RCA 46LA45RQ has no picture
    Try plugging in an audio source like HDMI and blindly flicking through inputs. Do you get sound? It's unlikely the LCD panel is bad. These sets have common issues with the blue poly capacitors near the inverter outputs going bad.
    • johnboy1313
      • Nov 2012
      • 1959
      If your set is like my 42la45rq, check the blue 15pf 6kv caps near the output from the PSU to the inverter.
      https://www.badcaps.net/forum/showthread.php?t=33092
      • Phydoux
        • Aug 2012
        • 83
        Is it easy to replace capasitors? This is the second tv that someone has told me to change the capasitors.
          Different type of capacitor, different fault modes. If you don't screw it up like in the example John posted, you're fine.
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • arbitarytwist
            Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
            by arbitarytwist
            Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
            Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
            03-01-2025, 01:16 PM
          • aazjo
            A1502 screen only issues
            by aazjo
            I have a MBP A1502 (early 2015, 820-4924) with a screen that will not turn on. I have swapped screens with a cracked test screen and the computer boots and the cracked screen works for both backlight and image. The black/blank screen appears to do nothing.
            I have collected resistant data from the cracked screen connector pins and submitted to OBData server:
            1 PPVOUT_SO_LCDBKLT OL
            3 I2C_BKLT_SCL 9.97M
            4 I2C_BKLT_SDA 9.89M
            5 PP3V3_S0_EDP_R 79.10k
            6 SMBUS_SMC_0_S0_SCL 321k
            7 SMBUS_SMC_0_S0_SDA 323k
            8 EDP_BKLT_PWM ...
            11-04-2021, 11:46 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
