I have an ad on Craigslist looking for TVs in need of repair. I got a call the other day regarding this set. The price was right so I bought it. Based on the described symptoms, brief backlight that shuts off, this video...
http://www.youtube.com/watch?v=no_e1kq6KnY
and this link...
http://www.tv-forums.com/forum/TV_Eq...cture_P103843/
I thought it would be a fairly easy fix. I was apparently wrong.
I got the TV opened and could immediately tell that it had been worked on before I got it. All four 15pf caps had been swapped out. Whoever removed the original caps did a number on the board. I can't find a schematic so, unfortunately, I'm not entirely sure if I can even repair this. I removed the caps that had been put in, cleaned the board a bit and tried to determine how to fix the damaged traces. I put the caps back in and did my best to fix the traces with jumpers. At this point, I checked for continuity where I believe there should be continuity and put the board back together. I still get a brief flash of the backlights. I'm not sure if the board was repaired correctly and I have a separate fault or if the board was not repaired correctly. Here are some pictures. Stay tuned for voltage readings when powered on.
and this link...
