Washed out negative image
  • pc55
    • Aug 2013
    • 28
    I have a Samsung 32" LCD TV, model LN32A330J1D, that has a washed out image that almost looks like the a negative of the picture. I found one fix for this system, which was to replace one of the IC chips on the Tcon board- well, I messed that up! Drag soldering in close space is not something I have mastered yet;-)
    Plan B- found a replacement really inexpensive ($23)- so replaced that and, while I had everything out, replaced the caps on the Power Board as well. Same issue- so I tortured and ruined the first Tcon board for nothing:-(
    I looked at the Mainboard more closely, and see what may be a damaged or burned component- but I am not sure what it is (yes, I am very new to this). It looks like, next to both of them, the marking on the board begins with the letter "L." From my Google search, that seems to indicate an Inductor, coil or bead. However, I cannot find anything that matches this- the only numbers are printed on top of each: 150 over 827
    They are both surface mounted with 4 connectors each, two to a side.
    Any thoughts on these are? Does the one look in bad shape? Pictures attached.
  • pc55
    • Aug 2013
    • 28
    Re: Washed out negative image
    Site is not uploading the higher res picture, so here is a lower res one:
      Those components look OK. Can we have a picture of your t-con? Do not rule out the chance you got a defective t-con.
      • pc55
        • Aug 2013
        • 28
        Thanks, Tom66- will post pic of the tcon board later- it is one of those designs where you have to remove a few things to get to it.
        Regarding those components I posted the picture of earlier- for my information- what are they?
          They look like inductors. Most likely for the Class D audio output (to the loudspeakers.)
          • rimwall
            Sony KD-65x7500D - double image - Tcon or Panel?
            by rimwall
            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
            11-18-2025, 02:09 AM
          • kca
            by kca
            Hello all ~
            08-31-2025, 06:38 AM
          • jason123
            ASUS PG27V Rolling Image - TCON?
            by jason123
            Hi there,
            My son's gaming monitor started having rolling image (vertical roll - See Video) similar to vertical sync issue, or T-CON problems in TVs. Has anyone see this? is it fixable or a throw away?
            I haven't even opened it up yet. Does it have a T-CON? Help is appreciated.
            It does this even with the monitor not connected to a computer / graphics card....
            11-01-2025, 05:41 PM
          • jason123
            Hisense 65R6E3 double-image / horizontal strips - TCON?
            by jason123
            Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
            07-19-2025, 08:07 AM
            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
            09-12-2024, 02:20 PM
