Samsung PS42Q96HD Clicking
  • sccs
    • Jul 2013
    • 16
    • United Kingdom
    hi guys,
    i have a samsung PS-42Q96HD that keeps clicking, heres what i have done so far,
    checked the power board, caps ect all good and have already been replaced, so i did the control board test and the set powers up and displays the test patterns perfectly, from this i assumed it was the av board that was switching the set on and off,
    i ordered a 2nd had board from the well known auction site, pugged it in a the set powered up and ran perfectly for hours, powered on and off a handfull of times to be sure, all was fine so i switched the set off and left it for the night,
    when i tried to power it up in the morning the set was dead no signs of life at all, so i swapped out the new board with the old one and we were back to square 1 with a clicking set, during more goggling i found the info on resetting the 24c256, so i swapped the chip off the replacement board onto the clicking board, and again the set powered up and ran perfectly.
    so again i did a power down and back on to check it was good and now back to the clicking!!
    i have tried shorting 5&6 on the 24c256 more times than i can remember with many variations on the length and timing of the hold/release, i also removed the chip and erased it manually and set comes on for a little longer than other times then reboots and goes back to clicking,
    a new blank chip i tried same happened, there is data being written to the blank chips but its never the same when i read it back, always bytes different, am annoyed at my self for not taking a dump of the eeprom before i fitted it, and i cant seem to find one on-line anywhere,
    any ideas as im running out of them feels like but i know the bloody thing works which is annoying, got another board on order should arrive late next week so i though i would ask you guys in the meantime
    sorry for the huge post but i wanted to add as much info as i could
    Regards
  • sccs
    • Jul 2013
    • 16
    • United Kingdom
    Re: Samsung PS42Q96HD Clicking
    Nobody got any ideas at all?
    • newtothis
      • Mar 2013
      • 1556
      • england
      Sorry post must of been over looked, Give me a minute to read #1
      • newtothis
        • Mar 2013
        • 1556
        • england
        Whats the number for PSU... BN44-xxxxxx?
        • sccs
          • Jul 2013
          • 16
          • United Kingdom
          sorry for the slow reply wasnt subscribed to the thread for email noticications
          have enabled it now,
          Psu is BN44-00194A
          av board is bn41-0813b
          Regards
          • newtothis
            • Mar 2013
            • 1556
            • england
            Check QX801 and QX802
            • sccs
              • Jul 2013
              • 16
              • United Kingdom
              these are fine as far as i can tell, can i ask if there is a specific reason you beleive the psu is the cause of the issue? as it works perfectly during a control board test.
              Regards
              • newtothis
                • Mar 2013
                • 1556
                • england
                Not a case of believing its the PSU, but something is causing this fault to occur.. best to look at every common fault first.
                • sccs
                  • Jul 2013
                  • 16
                  • United Kingdom
                  ok fair enough,
                  looking at the power board it looks like someone has already replaced the common parts,
                  guy that gave it to me said that he had it looked at and "they fitted a kit" but it was still clicking, so i guess what they fitted was the common ics and caps.
                  am trying to get hold of a dump of the 24c256 for this model to test it again, as when i installed the chip from the dead board it powered up fine
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • ohren
                    by ohren
                    09-08-2023, 05:24 PM
                  • C152Heavy
                    by C152Heavy
                    Summary for TL-DR readers:
                    • VCC pin (18) of PFC...
                    01-11-2023, 02:53 PM
                    09-07-2024, 05:50 AM
