Panasonic TC-P50V20B Scrolling Lines
  • DaveSan
    • Nov 2013
    • Brazil
    Hello, I have this panasonic for almost 3 years now. Every year a different problem comes up. First was the SC/Ysus board, it was replaced after 1 month of use. Then a problem with sound. Now this damn lines appeared all of a sudden. The lines are always there, in the whole screen, scrolling from top to bottom, in all inputs and menus. I already checked all connections and ribbons, but no success.
    I suspect the A(main) board is the guilty here, but I am not sure.
    So guys, what do you think? Can it be fixed or I will need a new board?
    Thanks.
    http://www.youtube.com/watch?v=V5SAe...feature=relmfu
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P50V20B Scrolling Lines
    definitely A-board,
    • DaveSan
      • Nov 2013
      • Brazil
      Thanks for the reply.
      One thing I forgot to mention is that the colors get unstable sometimes, flickering at bright areas, it gets more evident when the TV is displaying content with high contrast settings. I dont know if it is related to the lines problem or not, but maybe it helps to identify what component is failing. Any hints would be much appreciated.
      Anyway, I'll check the A-board and see if I can find any damaged components.
      Thanks once again.
        Interesting, do you have 50Hz or 60Hz electric service in your part of Brazil?
        • DaveSan
          • Nov 2013
          • Brazil
          60Hz.
          I was running some tests here, and I noticed that what is causing the flickering is not the refresh rate.
          It only happens when Normal or Dinamic mode is set. If I select any other mode and set the contrast, bright, color to 100 the image looks fine, no flickering.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • fredtred
            Physically bending the T-Con board creates horizontal dotted lines on OLED55CXPUA
            by fredtred
            Hello!
            I have been trying to solve this issue the past 12 months to no avail. I have been a lurker here during that time but finally decided to post my problem and see if anybody knows a solution.
            Problem
            My tv (OLED55CXPUA) has an issue where it displays horizonal lines of dotted artifacts.
            (See Attachment 1)
            Self Diagnosing
            After a very long troubleshooting period I traced the issue to the T-Con board. If I gently flexed/bend the board I could make the display go from GOOD to BAD and vice versa. I have ruled out the connectors/wires...
            10-29-2023, 01:09 PM
            After all of...
            07-13-2024, 08:14 PM
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            I happened several times, in the search for help from the web, to consult this very interesting forum.
            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
            Having said that I come to the gist of my post on the forum as the title suggests.
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
