Sony KDL40EX400 having trouble powering up
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Sony KDL40EX400 having trouble powering up
    it looks like your inverter uses the tab system that the tabs click into the inverter posts. Look and see if you're getting dark mark on one of the tabs of the inverter also what I do is in a dark room I carefully wiggle the inverter and look for an arc off of one of the tabs that's usually tell tale sign that it's a bad connection to a lamp. of course TV has to be functional the time in order to see a bad connection
    • tibimakai
      • Jan 2012
      • 3680
      That is the last place I haven't looked at yet and the tubes.
      I will check it out. Thanks for the pointer.
      • tibimakai
        • Jan 2012
        • 3680
        I have removed the board, but I haven't seen anything wrong there.Thanks for the idea anyway.
        • duckwize
          • Feb 2014
          • US
          I have a kdl-40ex400 that blinks 6 times as well. The first time I fixed it all I had to do is update the firmware. http://esupport.sony.com/US/p/swu-do...mdl=KDL40EX400
          I sold the tv and a week later I received "the original" tv back. The tv would not turn on. the green led would light and nothing else. would not power down. The backlight would not turn on, voltages were everywhere except for tcon voltages and the BL on voltage. I unhooked the IR board and all of a sudden the tv turned on showed the sony logo and shut off, repeats 3 times. I plug the IR board back in and I see the red led blink 6 times.
          I once again updated the firmware and I have a working tv again. The problem is as soon as the IR board is plugged back in the tv doesn't respond to turning on.
          Try updating the firmware and see what happens.
          • Phydoux
            • Aug 2012
            • 83
            I will try that. I am worried about looking for arcs considering that this may ruin the new board I installed so I guess I will try a firmware update and hope that works.
            Thanks!
            • daniel75
              • Nov 2014
              • venezuela
              #26
              hi, i have a question: i also have a KDL40EX400 with the 6 red blinking lights... i managed to set the "self check" diagnose (display+ch5+vol- + turn on), here's the results:
              Back <<
              002 MAIN_POWE 000
              003 AUD_PORT 000
              003 DC_ALERT 000
              004 BALANCER 000
              005 TCON_ERR 000
              005 HFR_ERR 000
              005 P_ID_ERR 000
              005 PANEL_POWE 000
              006 BACKLITE 040 <-- not good i suppose?
              007 TEMP_ERR 000
              04920 00186 04920
              [Menu] Exit
              Everything seems to be ok, but the backlight 40 means that i have to replace the lcd screen or something?
              please help me, thank you!
              • valvashon
                LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                by valvashon
                The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                11-24-2024, 12:08 PM
              • Carlos#2003%
                Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                by Carlos#2003%
                Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                02-15-2024, 07:52 PM
              • blake.s
                Sony XR-65X90J & Sony KD-55X80J Not Powering On
                by blake.s
                I have two separate tv's that are having the exact same symptoms. A Sony XR-65X90J and a Sony KD-55X80J. They both are not powering on at all and do not show any led light status. I am having issues with getting the backs off because both sets are the screwless type. Not sure if anybody has any ideas on if it is indeed a power supply issue or these types are known to have other issues.
                Also, any ideas on how to get the sets backs off?
                09-16-2021, 01:03 PM
              • dkneyle
                Sony KDL-46HX850 Can't upgrade/update firmware
                by dkneyle
                Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                09-25-2024, 10:44 PM
                Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 05:27 AM
