Panasonic TC-P50C2
    Re: Panasonic TC-P50C2
    Vscan seems fine, normally 140V above -Vad. -Vad should be around -180V.
    • Mark W
      • Nov 2013
      • 19
      Update - now back to 6 blinks.
      You're not going to beleive this but I had forgotten where the LED is located. The TV is lying face down on my bed so that I have easy access to all of the boards. Problem is that this faces the power switch and the LED down into the blanket on top of the bed. I have been using a stick to poke under the edge of the TV to operate the switch and was then looking at the back of the switch to see the LED which is ACTUALLY located a few inches to the left. Yes I know it seems impossible that I could count six blinks twice and then an hour later not see any. If any of you reading this are over the age of 70, you may understand. The short term memory gets shorter and shorter with each passing year.
      So now back to trying to figure out why the voltage at MID only gets to +15.68 volts. I have been reading this with a Fluke 87 DVM but now think I should look with the HP 501 scope.
      • Mark W
        • Nov 2013
        • 19
        tom,
        Did not see your post about Vscan being OK. Thanks, that is one less gremlin to chase.
        This is first forum I have ever used so am still learning how to navigate. Your post was first one on page 2 and I did not realize that page 1 was full.
          Could you have a short between MID and 15V?
          • Mark W
            • Nov 2013
            • 19
            Just measured 23.18k with + lead on +15 and -lead on MID
            Reversing the leads gives 71.4k.
            Readings are repeatable and take a couple of seconds to settle to the
            final value. Acts like capacitors charging. I suspect it is a FET or IGBT
            that is causing the problem. May learn more after I look with the scope.
            • Mark W
              • Nov 2013
              • 19
              Here is a picture showing MID on the top trace and +15V on the bottom.
              Sensitivity is 5V/div for both traces. Time base is 1 sec/div
              Sure looks like MID is being clamped to the +15V.
              • Mark W
                • Nov 2013
                • 19
                Back again. Have not given up on this TV. Taking a closer look at the schematic, it looks like a short between MID and +15V would result in smoke when Q16001 and Q16002 on the SS card turn on and drive MID to Vsus.
                Since there was no smoke, I have assumed that Q16001 and Q16002 are not being turned on. The drive signal for these two transistors (AA_UMH) originates on the A board and is buffered on the C2 and SS boards. The input to buffer IC17203 on the C2 card measures 680 ohms to gnd on all three buffered signals. This agrees with the value of R17217 and is a pretty good indication that the inputs are not shorted.
                Using the oscilloscope set to trigger on the rising edge in triggered mode, there is no signal on pins 2,4, or 5 when the TV is turned on.
                I suspect that the A board may be defective but I don't know enough to say this with certainty. There could be something else that the A board is looking at that needs to be in a certain state before it will generate the UMH/UML signals.
                Here are some voltage measurements taken with the DVM before the TV shuts down after two or three seconds: VSUS 191V, VSCN –39V, VAD –190V, MID 15.11V.
                I sent an email to the TV company that I bought the A card from on ebay with the above information but have not gotten a reply.
                Any suggestions would be appreciated.
                Mark W
                327
                • Mark W
                  • Nov 2013
                  • 19
                  Just about sure (99.9%) that the A board is bad. Talked to the guy that sold it to me and he is willing to refund my money if I return the board. He got it out of a TV with a cracked screen but I think maybe because of the craked screen, he never tried to power it up and assumed that the cards were good. I should have asked him about that but didn't think of it at the time.
                  Meanwhile, I have purchased a second A board which should arrive in a day or two. Hope this one works.
                  Mark W
                  418
                  • Mark W
                    • Nov 2013
                    • 19
                    Second A board arrived today from Baltimore. After allowing a couple of hours for it to warm up to room temperature, I installed it in the TV. Connected the DVM to measure the voltage “MID” on connector SS3 on the SS board, held my breath, and hit the power-on button. Oh no, DVM reads 15.11 volts just like before. However, about half a second later, the reading changed to 120V. Problem solved.
                    I am a little disappointed with the guy that sold me the first A board. He committed one of the cardinal sins of electronics ( and other disciplines as well). He ASSUMED the card he was selling was working but obviously did not test it. So he wasted a lot of my time and energy and probably the return postage since he wants the card back. I hope he doesn't sell it again.
                    The Panasonic service manual could use some improvements. Had I strictly followed the troubleshooting guides, I would have replaced almost every card in the TV and it still would not have resulted in a working TV. In my case, the A card was reporting errors that were the result of a failure on the A card. A more comprehensive self-test would monitor the signals that drive the other cards rather than ASSUMING that those signals are present.
                    On the positive side, I learned a lot about how a plasma TV works, derived some satisfaction from saving this one, discovered this Forum, and did a tiny bit to help preserve planet earth.
                    Mark W
                    463
                    • Andre Gilbert
                      by Andre Gilbert
                      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                      11-20-2024, 08:52 PM
                    • AquaMan Ua
                      by AquaMan Ua
                      05-17-2025, 09:40 AM
                    • gatto
                      LG 50PC56 keep burn Buffers Boards
                      by gatto
                      Hi, I’m new to the forum and this is my first post, so thank you in advance to having me, I have the fallowing problem, could someone please help
                      I have this LG 50PC56 which not display image on screen
                      I have already change Y-SUS and buffers 2 times! But this TV keep burning my buffers boards!
                      When I do install the new Buffers board I been able to see only the top half part of the screen for about 10 min, and then it blow up again! The IC get very hot and I saw some smoke come out from it, so now I have another set of buffers burn out
                      My question it is: I disconnect...
                      05-04-2022, 01:35 AM
                    • stecos
                      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                      by stecos
                      Hi everyone!
                      For my passion for technology I'm now collecting several...
                      11-28-2022, 11:39 AM
                    • aa10aa10
                      Panasonic Toughbook CF-33 mk1 BIOS repair
                      by aa10aa10
                      Good day,
                      I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                      I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                      01-21-2025, 06:13 AM
