Samsung LN32D403E4D - Jumpy/Double Image
    Re: Samsung LN32D403E4D - Jumpy/Double Image
    I think the panel just committed suicide from the high VGL voltage.
    • ohmmy
      • 182
      What's VGL voltage?
        Same as VOFFE.
        • Cornito
          Samsung UE55RU8000 reboot and then double image after heating up
          by Cornito
          Hello team,
          I'm back with another tv and another problem.
          I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
          First, reboot issue, I use tape Method to find out the right side that cases the issue.
          Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
          Then double image reduce in height and move to the top.
          The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
          When I...
          03-31-2024, 01:37 PM
          09-07-2024, 05:50 AM
        • howardc64
          TCL 49S405 double image
          by howardc64
          LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
          This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
          06-23-2025, 03:20 PM
        • shlomim412
          samsung ua55es6800 - no image
          by shlomim412
          hi
          having problem with samsung ua55es6800
          tv had backlight on, sound working - responds to the remote control but no image.
          check tcon board - had 12v in but no other voltages present.
          when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
          when leaving only left side connected - again no voltages and no image.
          put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
          kept trying to block less pins on the left ribbon cable...
          05-15-2024, 05:00 AM
          09-06-2024, 11:40 PM
