Panasonic Plasma TC-P50GT30 7 blinks SC board shorted
  • vouliman
    • Dec 2014
    • 9
    • canada
    #81
    Re: Panasonic Plasma TC-P50GT30 7 blinks SC board shorted
    it was a bar lower part, horizontal (left to right) aproxx: 3 inches large
    • vouliman
      • Dec 2014
      • 9
      • canada
      #82
      any idea ?
      • tw2005
        • Oct 2011
        • 6458
        What have you got to do the test? How high can your meter go for resistance?
        • tw2005
          • Oct 2011
          • 6458
          TRY THESE FOR RESISTANCE, TO GND. do both polarities(reverse the probes) and write down results
          • vouliman
            • Dec 2014
            • 9
            • canada
            #85
            I think my meter can go up to 40 M
            When I test the junction of R696-r9=699 I have 4M (not stable)
            to pin 3 of IC 724 2.6K (stable)
            When put on sound mode for continuity, no sound for short
            other test can I do ?
            • tw2005
              • Oct 2011
              • 6458
              Why don't you just disconnect the SD from the SC and also the ribbon between the SD/Su and measure the points I highlighted in the picture.
              • vouliman
                • Dec 2014
                • 9
                • canada
                #87
                Ok i will check that when I will return to home tonight,
                tanks !
                • CoinCoin88
                  • Nov 2014
                  • 20
                  • France
                  #88
                  A little update: I've received the repair kit from the UK. I replaced all 6 blow MOSFETs and 1 diode (DAF30A) which showed a significant difference in Vdrop with the new one.
                  I tested all combinations of legs for the 2 small SMD components (Q5xx and IC701), they were similar between previous and new ones, so i decided to give it a go. The TV works like a charm!
                  Thansk for your help, especially tw2005 ;-)
                  • tw2005
                    • Oct 2011
                    • 6458
                    oh, lovely, did you check out the screws? Do they have washers and spring washers?
                    • vouliman
                      • Dec 2014
                      • 9
                      • canada
                      #90
                      My result
                      with all connector unplug betwwen SC and SD and between SU and SD
                      VF5V : 39 M
                      VSCN_F : 40++
                      VFO : 40 ++
                      Probe invert
                      VF5V : 4,5 M
                      VSCN_F : 40++
                      VFO : 40 ++
                      • tw2005
                        • Oct 2011
                        • 6458
                        Originally posted by vouliman
                        My result
                        VF5V : 39 M
                        VSCN_F : 40++
                        VFO : 40 ++
                        Probe invert
                        VF5V : 4,5 M
                        VSCN_F : 40++
                        VFO : 40 ++
                        weird results compared to mine in the 2010 models. anyway nothing low or short. that's a nice cheap fix too. love it
                        • CoinCoin88
                          • Nov 2014
                          • 20
                          • France
                          #92
                          There were no screws in the kit (but I knew that prior to buying it). I did not have any washers at disposal but I'll probably add some soon. What i did is add some threadlock before mounting all screws back. I'll probably add washers in a near future and put some threadlock again.
                          Anyway, it's working, at a fairly low cost, and I've also got the new board I found at a good price, waiting in a drawer. So I'm prepared for (nearly) anything :-)
                          • tw2005
                            • Oct 2011
                            • 6458
                            yeah, I think if you get the chance to get hold of the correct screws with washers and spring washers could be handy, no flat washer reduces surface contact with those pads.
                            I'm getting mixed up with you and tehe other poster with the kits , thought you got the screws too.
                            • vouliman
                              • Dec 2014
                              • 9
                              • canada
                              #94
                              but when i replug the SD42,
                              i have for VF5V : 2.6K only
                              and 4-5 M for the other one....
                              normal ?
                              • tw2005
                                • Oct 2011
                                • 6458
                                normal ?
                                don't know, 2.6K would be correct as the 78M05 regulator has that resistance which ids the 5v supply and I suspect you are on the wrong pin on the other board? If it's working fine, forget about it.
                                • vouliman
                                  • Dec 2014
                                  • 9
                                  • canada
                                  #96
                                  Ok, i buy a repair kit for my SC board. Il will wait for the SD board.
                                  I hope that i will not scrap my repaired sc board when i will plug it.
                                  I dont know if a defect sc board can cause a horizontal bar but not scrap the SD.
                                  I will return to you when i Will receive my pieces ans fix the sc
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    So long as there are no shorts on the input side and no shorts between the output pins and Vfg it won't. You can always leave the SD/SU off and jumper SC50 on the Sc and fire it up for testing. If it starts with no error blinks then the Sc is good. If the worst happened after hooking up the buffer at least you knew the Sc was good.
                                    If you still have a defect on the lower buffer then you may have to look into it then.
                                    • vouliman
                                      • Dec 2014
                                      • 9
                                      • canada
                                      #98
                                      Finally i change 3 30f131 and 3 rpj30h2a. Unplug the SD and SU board and jump sc50.
                                      Start TV and grenn Light and fan run. Reconnect the SD and SU, and boom! Perfect picture, no more 7 blinking red light and no horizontal bar in the low part of the Tv on startup.
                                      Thanks everyone for your support and help !
                                      • dsi
                                        • Jan 2015
                                        • US
                                        #99
                                        New member here with 2011 TC-P50GT30 and 7 blinks.
                                        Thanks to all the info here I have confirmed that the SC board is bad with all the 6 transistors shorted out. Q531 read open between the legs as listed by tw2005 with my meter on 20M range, but I have short on the two outside ones (the side with 3 legs). I am assuming it is bad??? IC724 looks good. Since I need to fix my TV quick I have ordered new board, but still may try to fix my original one, possibly for future use since the kits are still available.
                                        Please let me know if I am missing anything else to check.
                                        • CoinCoin88
                                          • Nov 2014
                                          • 20
                                          • France
                                          #100
                                          I did not test Q531 the way you described (I just did mine as tw2005 suggested). You can always check on the one you'll get with th repair kit if it reads shorted between the legs you describe. If it doesn't, assume the one on your board is fried. If it does, well, it's just like yours on the board, so it's probably normal.
                                          A good indicator of correct repair is that there is no short anymore between both input pins (SC20)
                                          • jm1234
                                            Panasonic plasma TX-P42ST50 - 6 blinks
                                            by jm1234
                                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                            I checked that board for any obvious faults...
                                            05-22-2024, 06:59 AM
                                          • Alicat
                                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                            by Alicat
                                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                            Model number is TH-50PZ85U
                                            Power comes on and the red power light stays on solid.
                                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                            I also hear a few clicks.
                                            I also think my parents said there was a thunderstorm and the TV failed after that.
                                            Section 6 in the service manual talks about power and no screen,...
                                            10-30-2024, 10:09 AM
                                          • Yanleb
                                            Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                            by Yanleb
                                            Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                            I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                            D608, good
                                            D618 RF101L4S, good (See warning 1 below)
                                            D619 RF101L4S, good (See warning 1 below)
                                            D865 RF101L4S, shorted (See warning 1 below)
                                            IC464 Inverter HA MC74HC1G14, shorted...
                                            03-09-2020, 12:00 AM
                                          • nick31
                                            Panasonic Plasma ST50 TC-P55ST50 P55ST50 8 blinks
                                            by nick31
                                            My Oct 2012 panny plasma quit working yesterday.
                                            It was on when it happened. It let out a bit of burned plastic/circuit board smell. I was not able to find any burned parts though.
                                            Now it produces 8 blinks. According to the repair manual, that points to SS/SS2 board(s).
                                            I completed the steps in the guide: unplugged SS33, the TV turned on with a black screen, no blinking codes. Then I checked the continuity between pins 1 and 2 of the connectors SS52, SS54-SS57. The continuity is ok in all of them. Guide suggests to replace SS/SS2 boards so I placed an order...
                                            04-21-2021, 09:56 AM
                                          • Biruslapio
                                            Panasonic P58V11B 8 and 12 blinks error "fix"
                                            by Biruslapio
                                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                            04-13-2021, 07:13 AM
