Transonic TC2884STB DVB-T HDTV Tuner STB - unknown capacitor brand
  • Agent24
    I see dead caps
    • Oct 2007
    • 4953
    • New Zealand
    Got a Transonic TC2884STB here (Transonic is a brand 'exclusive' to a cheap department store in NZ) but no doubt from some big Chinese OEM.
    Symptoms: Turns on but remote\buttons unresponsive. Doesn't output video signal.
    I can make it work by blasting the mainboard with a hairdryer for a couple of minutes. This leads me to suspect marginal capacitors.
    The problem is they are brands I have not heard of and (so far) cannot find online.
    The PSU uses "KSJ" with no series (but the variety of sleeve colours probably means the series are colour-coded rather than labelled)
    The mainboard uses "SWC" and they all appear to be "KM Series"
    They do turn up here: http://capacitor.web.fc2.com/s_other.html#swc but there is no web address.
    They all seem to be either 10, 100, 220 or 470uF.
    What would be an advisable series as a general (and cheap) replacement, assuming no datasheets can be found?
    -David VanHorn
  • mariushm
    • May 2011
    • 3799
    Re: Transonic TC2884STB DVB-T HDTV Tuner STB - unknown capacitor brand
    It's worth a shot replacing those capacitors, but based on "heating it makes it work" it could also be some surface mount stuff (ceramic resistor or capacitor) make contact with pcb once the copper on pcb expands with heat.
    Yeah, standard capacitors should do it, I don't think you need to use anything fancy.
    • Agent24
      I see dead caps
      • Oct 2007
      • 4953
      • New Zealand
      Any recommendation for a suitable brand\series? I normally lookup the original datasheet but in this case can't find it.
      I assume Panasonic FC or similar would be a sensible choice - Low ESR but not super low.
      -David VanHorn
      • Orpheous
        • Oct 2010
        • 43
        Just found the same looking caps in a Laser brand DVD player, model HD0020 from a cheap department store here in Australia (Kmart)
        The one marked KSJ had LOWESR written on it, so I used a Rubycon MCZ to replace it... mostly because that's all I had here at home.
        I only replaced the one suspiciously bulging cap, then replaced the power board and bench tested it and it seems to be working ok.
        Might consider ordering replacements for the rest of the board too before it goes back into service.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4953
          • New Zealand
          I'd say replace the lot, without even a website it's going to be a crap capacitor brand.
          I have some for this TC2884STB on order, which should ship today, will post here what the results are
          -David VanHorn
          • Orpheous
            • Oct 2010
            • 43
            I think I will. It's a friends DVD player. Finding a supplier of decent caps here in Australia can be painful though if you don't want to wait for an international order and they're not the ones I usually keep on hand, but I'm sure she won't mind waiting a little while to get it running again.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4953
              • New Zealand
              Tried RS Components or Farnell? That's where I buy mine.
              -David VanHorn
              • Orpheous
                • Oct 2010
                • 43
                Thanks for that! Last time I stocked up was a few years back. I bought from The Cap King and this main site. Completely forgot about those two that you mentioned! If they have Aussie stock I'll order some in for that and a couple of other jobs that have been lying around for too long
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4953
                  • New Zealand
                  They should have more than enough Even if they don't, they usually have USA or UK stock they can backorder and ship in a week or so, and you don't pay extra shipping either.
                  Badcaps.net has good stuff too but if you're like me and just do a small order occasionally, the international shipping is a big problem, unfortunately.
                  -David VanHorn
                  • Orpheous
                    • Oct 2010
                    • 43
                    Finished work at 5am. Just got home. I checked both RS and Element14 for Nichicon PW series caps in the right ratings. Went through the shopping cart, element14 (formerly Farnell) only allows a minimum of 5 or 10 of each. I only need 1 x 400V 10uF, 1 x 50V 22uF and 3 x 100uF caps.
                    Both shopping carts came to just under $20 including freight!
                    I'd hate to have to go back to Jaycar for Samxon and Capxon's, but I can get all 5 there for $4.50 :/ Grrr
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      Samxon are okay except the GF and GK series. Samxon KM should be suitable replacements.
                      A working TV? How boring!
                      • Orpheous
                        • Oct 2010
                        • 43
                        Thanks for that. I'll drop in to the local branch after the weekend. The Jaycar site doesn't specify series or brand, just basic specs and a generic picture that's too blurry to see:
                        or one with multiple caps in it:
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4953
                          • New Zealand
                          It doesn't have to be Nichicon PW, you could buy a comparable series from another manufacturer. I do notice that RS New Zealand has often 5 MOQ for most things, but Farnell often you can buy just one.
                          Is Jaycar actually selling CapXon? If they are that's pathetic, CapXon are useless.
                          Samxon would be OK though. BUT my local Jaycar sells only "Suntan" brand, while the photos online say Samxon, so beware... that's why I don't bother, just go to RS usually.
                          -David VanHorn
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4953
                            • New Zealand
                            I recapped this one yesterday, unfortunately the problem has not been resolved. At first test it did the same thing, no video output and buttons\remote not responding.
                            I tried it a few more times and after the CPU heatsink became warm it worked, a-ha I thought, perhaps it's bad BGA soldering here?
                            Problem is I tried it again last night and this morning when it was stone cold and it worked just fine, where before it had not done so as I recall. So this looks like some pain in the ass intermittent that may or may not be heat related. Great.
                            -David VanHorn
                            • Prolog
                              RTX 3080 FE Identifying capacitor
                              by Prolog
                              Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                              I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                              I hope these photos make it clear which component I am referring to:
                              (yes, the soldering is a bit botched from removing the blown one, I know)
                              I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                              12-01-2024, 08:27 PM
                            • chth96
                              If I replace with inferior capacitor, Is it No harm to other IC components at all?
                              by chth96
                              I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                              Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                              It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                              So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                              I know that these capacitor will not last as long as nichicon capacitor...
                              12-22-2023, 04:34 AM
                            • chth96
                              How can I test non-polarized capacitor?
                              by chth96
                              I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                              I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                              And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                              I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                              06-02-2024, 07:31 PM
                            • chth96
                              Is it no harm to replace with capacitor without ripple current rating?
                              by chth96
                              When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                              Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                              But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                              Rubycon YK DataSheet (b...
                              04-19-2024, 05:19 AM
                            • chth96
                              Should I replace polymer capacitor?
                              by chth96
                              a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                              I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                              Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                              Is this ESR value of polymer capacitor correct?...
                              11-18-2022, 04:22 AM
