hep with a part on dmtech mainboard
  • wreksta
    • Aug 2013
    • 508
    • england
    hi all I have this dmtech 37" tv when I switch on I get a ticking from either of these parts the the buck reg marked 2576-3,3dd or that coil near the ic legs marked 530 the ic to touch burns as does the coil so want them replaced
    shown in pic
    can you tell me if I can use a coil ferrite component marked up as 470 that's all that's on it
    and can I use this ic 1501 then under that has 0647el in place of the offending 5 legged ic
    thanks in advance
  • wreksta
    • Aug 2013
    • 508
    • england
    Re: hep with a part on dmtech mainboard
    anyone
      I'd check the buck diode, which will be on the same pin as inductor & chip, is not shorted. If not, could be the load shorted. You can try powering that part externally with a high current to blow out the short, but be careful to use current limiting.
