Re: Quirky 42" Phillips Plasma TV (42PF9631D-37)
The TV turned-on again today...and has been on for ~6-hrs. I think I've figured out the problem. This time while I was powering it on, I was insulting it. Maybe it just needs to be knocked down a peg or two from time-to-time. I haven't tried hitting it yet, but I think there is a line and physical violence would be crossing it.
Yesterday, while the TV was throwing the 6-3 code, I tried to disconnect the audio board as you suggested, capkid. Sorry I didn't mention it before. It didn't seem to do anything. The TV still gave me the 6-3 error code. No video. Thank you for the suggestion, though.
I scanned the PSU board while I had it out of the TV twice with a flashlight. Like I said, I have an untrained eye, but I didn't see any obvious shorts, damaged traces, or faulty components. On a side note, can anyone tell me what the "clicking" noise is I hear coming from the PSU when I initially plug-in and power-on the TV? There's usually one click when I initially plug it in, and one click when I hit the "power" button. *Edit: so the clicking is likely a relay and indicative of one or more faulty caps.*
I'm part-way through tom66's "A guide to fixing/troubleshooting some common plasma TV problems." While the TV was throwing the 6-3 error code yesterday, I tried unplugging the z-sus and y-sus (or at least what I think are the z-sus and y-sus) as suggested with no positive results, no video or audio, just the 6-3 error code. When I next power-off the tv and it gives the 6-3 code again, I will try to unplug the upper and lower buffers, if I can figure out where they are located...
I will also check the fuses on the PSU (there are four, I believe) with a DMM when it is next powered-off.
I tried plugging the TV in this morning before I went out to run errands for a few hours. It only gave me the 6-3 error code. No audio/video. When I came back, I plugged the TV in and it powered-on. It took ~10-seconds to get video. The TV has been on ~6-hours now and the PQ doesn't seem to have degraded. No led flashes. The led (printed "LED8001") on the PSU board is on steadily.
I tried touching the larger capacitors on the PSU while the TV is on (which, I'm sure, is a smart idea) and none of them are warm to the touch.
I've tried to adjust the video (saturation, color, color temp, brightness, tint) because the reds seem to be much more red than the blues are blue. When I turn-up the saturation, color, and color temp, the blues increase, but so do the reds. Is there some way to increase blues (cooler temp colors) without increasing reds (warmer temp colors) as well? I've included pictures of a LED display vs. the plasma display in question. I was using a point-and-shoot camera for the plasma, but I think I captured the PQ pretty closely to what I see in real-life. The LED display (first pic) is ~1-yr-old and the plasma display is ~7-yrs-old.
