hitachi L42S02A
  • willyam1
    • Feb 2012
    • 112
    • israel
    hitachi L42S02A
    HI.
    problem is sound ok no backlight.
    inverter 6632L-0503B.
    24VOK.
    FROM MAIN BOARD- 3.3V OK INV/ON 3.1V OK .
    4 FET NOT SHORT SMD FUSE OK.
    INV IC CONTROLLER OZ9966SN.
    Icheck all resi diode and tra smd all ok.
    any schematic to this inv or anyone already repear this inv any data to this ic.
    i change 3 capi 680/35 but no cure.
    thanks willyam1
    Re: hitachi L42S02A
    Does LED light on inverter?
    • willyam1
      • Feb 2012
      • 112
      • israel
      Re: hitachi L42S02A
      no i dont see any led.
      willyam.
      i notice that the vcc pin8 in the comperator 2903 is missing i will check were is the suooly to that pin.
      willyam
      • willyam1
        • Feb 2012
        • 112
        • israel
        Re: hitachi L42S02A
        need schematic.
        willyam
          Re: hitachi L42S02A
          No schematics for LG inverters exist AFAIK, apart from the ones which have been reverse engineered. However, if you don't even get the thing attempting to light the bulbs, I'd look towards the main controller chip being bad, or one of its supply voltages being low.
          • Jaime Morillo
            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
            by Jaime Morillo
            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
            The TV was stuck on the logo and I couldn't access the update menu.
            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
            The image result was good, but the image is inverted.
            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
            08-18-2025, 11:38 AM
          • massimomax
            Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
            by massimomax
            Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
            spero che qualcuno può averlo per riprogrammare eprom. grazie
            Post in English !!!
            I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
            02-28-2025, 07:27 AM
          • dragometin
            Hitachi 40HYC42
            by dragometin
            TV Model: Hitachi 40HYC42
            Power Supply: 17IPS71
            MainBoard: 17MB95M
            Panel: VES400UNDS-2D-NO3
            When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
            I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
            Is there any variants on 17IPS71 power supply's?
            UART output pins 10 and 12 on scart connector:
            Code:
            12:24:04.595
            08-08-2024, 05:53 AM
          • sotodefonk
            Help finding the correct model of a T-Con board on my Hitachi TV
            by sotodefonk
            Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
            I opened the tv to access the board and took the shared pictures of the T-Con board.
            I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
            I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
            Inspecting...
            06-28-2024, 04:39 PM
          • dicky96
            Hitachi V19B01922 Channel Tune problem
            by dicky96
            Hi Guys
            I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
            He also has an LG TV, so three screens in the bar
            I installed three Satlink ST-6503 DVB-T Modulators
            This model https://www.aliexpress.com/item/32916553905.html
            These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
            02-09-2023, 09:20 AM
