Picked up this TV for $20, it was manufactured in 08' serial #J33855376. It shows no signs of life, no sounds, blinking lights, nothing. With the inverter disconnected the main power supply is outputting 169.2v, it has 345v stamped on the board by that connection. Transistors tested good, diodes tested good, fuse was good, No signs of bulging/leaking caps or burn marks anywhere. The power supply for this TV is out of stock everywhere and it's pretty expensive even if I can find one, so I'm hoping I can find out which specific component has failed. I don't have an ESR meter or anything, just a fluke 179 and a soldering iron, and my probes are too fat to fit in the test holes, I will have to pick some up that fit.
Edit: I found the service manual on this forum, that should help a ton, but if anyone has experience working on this TV it would be helpful to know which components I should check first.
